[STM8] 发送中断编程思路
730|5
 楼主| Edisons 发表于 2016-9-20 16:18 | 显示全部楼层 |阅读模式
u8 TxBuffer[2];
u8 TxCounter=0;
u8 count=0;
void USART_SendData_Int(u8 *str)
        while(*str != '\0')
                TxBuffer[count++] = *str++;
        USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
void delay(void)
        long i,j;
        for(i=0;i<1500;i++)
                for(j=0;j<2000;j++);
int main(void)
    USART_Configuration();
    NVIC_Configuration();
    while (1)
          USART_SendData_Int("012345678901234567890123456789012345\n");
          USART_SendData_Int("abcdefghijklmn\n");
          delay();
void USART_Configuration(void)
  USART_InitTypeDef USART_InitStructure;
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  USART_InitStructure.USART_BaudRate = 115200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_Init(USART1, &USART_InitStructure);
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
  USART_ClearFlag(USART1,USART_FLAG_TC);
  USART_Cmd(USART1, ENABLE);
void NVIC_Configuration(void)
        NVIC_InitTypeDef NVIC_InitStructure;
        NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 7;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
        NVIC_Init(&NVIC_InitStructure);
void USART1_IRQHandler(void)
  if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
    USART_SendData(USART1, TxBuffer[TxCounter++]);
    USART_ClearITPendingBit(USART1, USART_IT_TXE);
    if(TxCounter == count)
这个程序经过调试,在串口调试助手上一点问题都没有!!!不过似乎从程序上看问题很多:1、我定义的串口缓存TxBuffer[2],为什么大小只有两个字节(应该说是任意字节大小都可以),我程序在发送数据时,数据大小远远超过两个字节,但是却没报错,更是还能正确运行。。。没懂!?2、我定义的两个全局变量u8 TxCounter=0;u8 count=0;每发送一次数据,都会相应自加上数据的长度,程序中没有对其清零, 却似乎永远没有溢出的迹象。怎么解释?
_gege 发表于 2016-9-20 16:26 | 显示全部楼层
查询方式:发送数据——先发后查;
                     接收数据——先查后收。
中断方式:发送数据——发送、等待中断、中断中发送;
                    接收数据——等待中断、在中断中接收。
Mozarts 发表于 2016-9-20 16:31 | 显示全部楼层
查询发送:发送完一个字节,等待发送完,继续发送下个字节,直到整个字符串发送完吧
Listate 发表于 2016-9-20 16:43 | 显示全部楼层
中断发送,  只有在中断时占用CPU资源吧。
bbapple 发表于 2016-9-20 16:45 | 显示全部楼层
串口发送中断我只用过一次
handleMessage 发表于 2016-9-20 16:54 | 显示全部楼层
只要将第一个字节送进串口发送数据寄存器,就可以在串口发送中断里依次把剩余的字节都发送完。
