STM32F103Z-FATFS R0.07e SD 卡 DMA四线传输(源码)
4095|2
 楼主| linminjun 发表于 2010-3-25 17:12 | 显示全部楼层 |阅读模式
FATFS R0.07e  支持长文件文件名, SD.rar (335.43 KB, 下载次数: 892)
        f_mount(0, &fs);
        f_open((FIL*)&fsrc, "Hello World.txt", FA_OPEN_ALWAYS | FA_WRITE);
        sdres = f_lseek((FIL*)&fsrc, (&fsrc)->fsize);
        while (1)
                resTemp = f_printf((FIL*)&fsrc, "扫描范围:±%d.%dV  扫描速率:%3dmV/S  电压单位:mV  电流单位:nA \r\n",\
        5, 10,\
        35 );
                f_puts("\r\n\r\n",(FIL*)&fsrc);
                f_sync((FIL*)&fsrc);
另外请假加密问题:
void PasswordCheckout(void)
   volatile unsigned int Dev_Serial[3] = {0};
    Dev_Serial[0] = *(volatile unsigned char*)(0x1ffff7e8)+1;
    Dev_Serial[0] |= (*(volatile unsigned char*)(0x1ffff7e9)-2)<<8;
    Dev_Serial[0] |= (*(volatile unsigned char*)(0x1ffff7ea)-1)<<16;
    Dev_Serial[0] |= (*(volatile unsigned char*)(0x1ffff7eb)+5)<<24;
    Dev_Serial[1] = *(volatile unsigned char*)(0x1ffff7ec)+0;
    Dev_Serial[1] |= (*(volatile unsigned char*)(0x1ffff7ed)-6)<<8;
    Dev_Serial[1] |= (*(volatile unsigned char*)(0x1ffff7ee)+7)<<16;
    Dev_Serial[1] |= (*(volatile unsigned char*)(0x1ffff7ef)-9)<<24;
    Dev_Serial[2] = *(volatile unsigned char*)(0x1ffff7f0)+8;
    Dev_Serial[2] |= (*(volatile unsigned char*)(0x1ffff7f1)-7)<<8;
    Dev_Serial[2] |= (*(volatile unsigned char*)(0x1ffff7f2)+3)<<16;
    Dev_Serial[2] |= (*(volatile unsigned char*)(0x1ffff7f3)-6)<<24;
   while(1)
      if(Dev_Serial[0] == 0x04fefd38)   //烧入时候先读出该值
          if(Dev_Serial[1] == 0x2d403058)
             if(Dev_Serial[2] == 0x3d27424f)
              break;
请教前辈们这样利用MCU ID 加密可行不?应该怎么做?
 楼主| linminjun 发表于 2010-4-3 16:05 | 显示全部楼层
个人闲置5片 全新STM32F103ZET6 五片包邮 ,一片36元,另赠一片 STM32F103ZCT6 (该片是自己焊接时候有两个角脚在一起,还没去处理,处理一下,就能用)http://item.taobao.com/auction/item_detail.htm?item_num_id=4588514713
a121597302 发表于 2010-12-4 20:10 | 显示全部楼层
感谢分享
