KL25的UART0求大神
1275|4
 楼主| 医家木栝 发表于 2016-10-15 11:07 | 显示全部楼层 |阅读模式
#include "MKL25Z4.h"
#include "main.h"
#include "uart.h"
#include <stdarg.h>
void UART0_init (void)
  SIM_SCGC4 |= SIM_SCGC4_UART0_MASK;
  SIM_SOPT2 |= SIM_SOPT2_UART0SRC(0x1) ;
  SIM_SCGC5 |=SIM_SCGC5_PORTD_MASK;
  PORTD_PCR6 = PORT_PCR_MUX(3);
  PORTD_PCR7 = PORT_PCR_MUX(3);
    // Disable UART0 before changing registers
    //UART0_C2 &= ~(UART0_C2_TE_MASK | UART0_C2_RE_MASK);
        /* configure uart1 for 8-bit mode , no parity */
    //UART0_C1 = 0U;
    /* calculate the sbr value. */
    UART0_C4=0x03;
    UART0_BDH = UART0_BDH_SBR(0x4e2>>8);
    UART0_BDL = UART0_BDL_SBR(0x4e2);
   /*UART0_C4   = 0x03;                   // baud rate = 19200 with 48MHz clock
  UART0_BDL  = 0xE8;
  UART0_BDH  = 0x03;*/
    //UART0_C3 = 0U;
    //UART0_S1 = 0x1FU;
    //UART0_S2 = 0U;
    /* enable the tx and rx  */
    //UART0_C2 |= (UART0_C2_TE_MASK | UART0_C2_RE_MASK);
void UART0_PutTxData(uint8_t txData)
    UART0_D = txData;
bool UART0_IsTxBufferEmpty(void)
    return ( 0U != (UART0_S1 & UART0_S1_TDRE_MASK) );
  //return (UART0_S1&= ~UART0_S1_TDRE_MASK);
bool UART0_IsRxBufferFull(void)
    return (0U != (UART0_S1 & UART0_S1_RDRF_MASK) );
//return (UART0_S1&= ~UART0_S1_RDRF_MASK);
/*void UART0_PutTxDataBlocking(uint8_t txData)
  UART0_C2 |= UART0_C2_TE_MASK;
    while (!UART0_IsTxBufferEmpty() ) {}
    UART0_PutTxData(txData);
    while (!UART0_IsRxBufferFull() ){
    ;                                                 // wait if transferring
    UART0_D = (txData/256);
/*uint8_t UART0_GetRxData(void)
    //return (uint8_t)(UART0_D);
  UART0_PutTxData(txdata);
  UART0_D = (UART0_D/256);
uint8_t UART0_GetRxDataBlocking(void)
    while (!UART0_IsRxBufferFull() ) {}
    return UART0_GetRxData();
哪里错了
 楼主| 医家木栝 发表于 2016-10-15 11:10 | 显示全部楼层
但求不沉
 楼主| 医家木栝 发表于 2016-10-15 15:03 来自手机 | 显示全部楼层
再顶顶
z00 发表于 2016-10-15 22:40 | 显示全部楼层
可以参考官方的KSDK开发库的写法
 楼主| 医家木栝 发表于 2016-10-17 19:27 | 显示全部楼层
可以参考官方的KSDK开发库的写法
我用IAR编译器,有的库没有
