STM32F103的CAN问题
4776|6
 楼主| jzxeagle 发表于 2010-3-26 15:17 | 显示全部楼层 |阅读模式
请问:我使用STM32F103的can功能,设置为loopback可以正常工作,一旦设置为normal接收不到数据,也不发送数据?
sunmonth 发表于 2010-3-26 15:19 | 显示全部楼层
说明你没用好,我用很正常
 楼主| jzxeagle 发表于 2010-3-26 15:51 | 显示全部楼层
没用好诗肯定的,就是不知道哪里出问题了
 楼主| jzxeagle 发表于 2010-3-26 15:52 | 显示全部楼层
TestStatus CAN_Interrupt(void)
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CanTxMsg TxMessage;
  uint32_t i = 0;
  /* CAN register init */
  CAN_DeInit(CAN1);
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
//  CAN_InitStructure.CAN_TXFP=ENABLE;
//  CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack;
  CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler=1;
  CAN_Init(CAN1, &CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=1;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=CAN_FIFO0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* CAN FIFO0 message pending interrupt enable */
  CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
  /* transmit 1 message */
  TxMessage.StdId=0x00;
  TxMessage.ExtId=0x1234;
  TxMessage.IDE=CAN_ID_EXT;
  TxMessage.RTR=CAN_RTR_DATA;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xDE;
  TxMessage.Data[1]=0xCA;
  CAN_Transmit(CAN1, &TxMessage);
  /* initialize the value that will be returned */
  ret = 0xFF;
  /* receive message with interrupt handling */
  i=0;
  while((ret == 0xFF) && (i < 0xFFF))
    i++;
  if (i == 0xFFF)
    ret=0;
  /* disable interrupt handling */
//  CAN_ITConfig(CAN1, CAN_IT_FMP0, DISABLE);
  return (TestStatus)ret;
ST_ARM 发表于 2010-3-26 16:12 | 显示全部楼层
你用两块板子互连了么?
贝多芬爵士 发表于 2011-4-29 10:40 | 显示全部楼层
我的也是这样的问题!!
yinyangdianzi 发表于 2011-5-5 16:20 | 显示全部楼层
2个都是公的。。。。。。怎么连?
