[ARM入门] YL-KL26Z中DAC的问题
1212|4
 楼主| 512751875 发表于 2016-10-22 16:49 | 显示全部楼层 |阅读模式
求教一下  这个例程的意思,LZ烧录片子中,原理图上的LP1就一直响着,请问这是什么功能啊,求指教  谢谢!
  1. #include <includes.h>
  2. uint16 gu16WaveformBuffer[33] = {0};
  3. uint16 gu16SineWaveBuffer[]  =  {2047,2446,
 楼主| 512751875 发表于 2016-10-22 16:51 | 显示全部楼层
uint16 gu16SineWaveBuffer[]  =  {2047,2446,2830,3184,3494,3749,3938,4055,4094,4055,3938,3749,3494,3184,2830,2446,2047,
                                 1648,1264,910,600,345,156,39,0,39,156,345,600,910,1264,1648,2047,0xFFF};
uint16 *pWaveform, *pGenerateData;
void myDelay (INT32U ulTime)
    INT32U i;
    i = 0;
    while (ulTime--) {
        for (i = 0; i < 2000; i++);
int  main (void)
                int i,num=2;
    INT16U uiVout = 1;                                 /* ¼ÆËãת»»Öµ                   */
    SystemCoreClockUpdate();
    uart0Init(9600,0,0,8,1);
                printf("DAC generated take SineWave Test ");
                dacInit();         /* DAC³õʼ»¯                    */
                while (1)
                                for(i=0;i<33;i++)
                                        gu16WaveformBuffer[i]=gu16SineWaveBuffer[i];
                                        dacTrigger(gu16WaveformBuffer[i]);                                             /* DACÊä³ö                      */
                                        myDelay(1);
                                        if(i==33) i=0;
 楼主| 512751875 发表于 2016-10-23 08:18 | 显示全部楼层
 楼主| 512751875 发表于 2016-10-23 09:39 | 显示全部楼层
 楼主| 512751875 发表于 2016-10-24 17:53 | 显示全部楼层
有没有人给说一下啊   大二学生 着急啊
