诡异现象之TIM2 ——大侠救命
3707|6
 楼主| 戒指320 发表于 2010-3-26 21:50 | 显示全部楼层 |阅读模式
TI, ST, vi, rc, ic
用tim2做个250us的定时
用来把led翻转  本来是2s的翻转
但现在实际是1s翻转
看了半天不知道为什么
各位大侠 帮分析下,程序如下:
谢谢大家!
void TIM2_config(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  TIM_TimeBaseInitTypeDef  TIM_BaseInitStructure;
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE); //使能时钟
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQChannel; //使能中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
//时基模块设置
//中断频率= apb1 clock/(perscaler+1) /period
//TIM2 使用内部时钟
//TIM_InternalClockConfig(TIM2);
//TIM2基本设置
//设置预分频器分频系数35,即APB1=72M/2, TIM1_CLK=36M/36=1MHz
//TIM_Period(TIM2_ARR)=250,计数器向上计数到250后产生更新事件,计数值归零
//向上计数模式
//TIM_RepetitionCounter(TIM2_RCR)=0,每次向上溢出都产生更新事件
// wave文件为4KHz mono pcm编码 ,所以取中断时间 为250us  4kHz=1M/250
    TIM_DeInit(TIM2);
TIM_BaseInitStructure.TIM_Period = 250;
TIM_BaseInitStructure.TIM_Prescaler = 35;//0
TIM_BaseInitStructure.TIM_ClockDivision = 0;
TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_BaseInitStructure.TIM_RepetitionCounter = 0;
TIM_TimeBaseInit(TIM2, &TIM_BaseInitStructure);
    //TIM_PrescalerConfig(TIM2, 35, TIM_PSCReloadMode_Immediate);//35+1预分频
//清中断,以免一启用中断后立即产生中断
TIM_ClearFlag(TIM2, TIM_FLAG_Update);
//使能TIM1中断源
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
//TIM1总开关:开启
TIM_Cmd(TIM2, ENABLE);
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
void NVIC_Configuration(void)
//  NVIC_InitTypeDef NVIC_InitStructure;
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
  /* Configure the NVIC Preemption Priority Bits */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
//  NVIC_InitStructure.NVIC_IRQChannel = SDIO_IRQChannel;
//  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
//  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
//  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//  NVIC_Init(&NVIC_InitStructure);
中断程序
void TIM2_IRQHandler(void)
  vu16 i;
if(TIM_GetITStatus(TIM2,TIM_IT_Update)!=RESET)
TIM_ClearITPendingBit(TIM2,TIM_IT_Update);
m++;
if(m>=8000)
m=0;
itcount++;
  i= GPIO_ReadOutputData(GPIOF);
   i=i^0x0200;
   GPIO_Write(GPIOF,i);
香水城 发表于 2010-3-26 22:17 | 显示全部楼层
请注意,按照你的配置TIM_CLK是72MHz而不是36MHz。
这个问题已经讨论过无数次,请搜索一下吧。
 楼主| 戒指320 发表于 2010-3-26 22:27 | 显示全部楼层
可是这里 设为div/2 了啊?
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    RCC_PCLK1Config(RCC_HCLK_Div2);//、、、、、
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
 楼主| 戒指320 发表于 2010-3-26 22:32 | 显示全部楼层
2# 香水城
麻烦香主  说明白点,小弟不懂啊
或者给个讨论的连接?
 楼主| 戒指320 发表于 2010-3-26 22:51 | 显示全部楼层
通过仔细 看芯片手册 明白怎么回事了。感觉问这个问题有点丢人。
xinyun266 发表于 2010-3-29 09:12 | 显示全部楼层
还有一点就是中断函数结时中要把更新标志位清零,好像你没有
个人签名:淘宝小店: http://shop73275611.taobao.com
37
