捕获程序
841|12
 楼主| huangchui 发表于 2016-10-28 23:18 | 显示全部楼层 |阅读模式
ui, ISP, se, AC, TE
   捕获方波信号,算出频率,占空比
#include  <msp430x14x.h>
#include  "1602.h"
#include  "1602.c"
#define uint unsigned int
#define uchar unsigned char
uchar shuzi[] = {"0123456789.k"};
//uchar tishi[] = {"FZHzk"};
uint start=0;
uint end=0;
uint tem=0;
uint temp=0,overflow;
void chuli(uint a,uint b);
void Init_CLK(void);
/************************主函数****************************/
void main(void)
  uint c,d;
  WDTCTL = WDTPW+WDTHOLD;                   //关闭看门狗
  /*下面六行程序关闭所有的IO口*/
    P1DIR = 0XFF;P1OUT = 0XFF;
    P2DIR = 0XFF;P2OUT = 0XFF;
    P3DIR = 0XFF;P3OUT = 0XFF;
    P4DIR = 0XFF;P4OUT = 0XFF;
    P5DIR = 0XFF;P5OUT = 0XFF;
    P6DIR = 0XFF;P6OUT = 0XFF;
  P6DIR |= BIT2;P6OUT |= BIT2;              //关闭电平转换
  P5DIR|=BIT5;P5OUT&=~BIT5;               //关闭数码管显示
  P6DIR|=BIT6;P6OUT&=~BIT6;                 //半闭数码管显示
  P6DIR|=BIT5;P6OUT&=~BIT5;                 //半闭数码管显示
  LcdReset();                               //复位1602液晶
// DispNChar(2,0,12,tishi);                  //显示提示信息
  Disp1Char(0,0,'Z');                      //显示电压单位
  Disp1Char(1,0,':');
  Disp1Char(0,1,'F');
  Disp1Char(1,1,':');
  Disp1Char(13,1,'H');
  Disp1Char(14,1,'z');
  Init_CLK();
  P1SEL |= BIT2;                             //设置P1.2端口为功能模块使用
  P1DIR &=~BIT2;
  //TACTL |=TACLR;
  TACTL = TASSEL_2+TAIE+MC_2+TACLR;          //定时器A时钟信号选择SMCLK 8M,清计数寄存器,使能中断,同时设置定时器A计数模式为连续增计模式
  TACCTL1 =CM_1+SCS+CAP+CCIE+CCIS_0;                //输入上升沿捕获,同步,capture模式 CCI1A为捕获信号源(P1^2???),中断使能
  //TACCTL0 &=~CCIFG; //清CCR2 的标志位
  //中断允许
  _EINT();
   LPM0;
   _NOP();
   c=overflow*65535+temp-start;
   d=overflow*65535+end-start;
  chuli(c,d);
  while(1);
void Init_CLK(void)
unsigned int index;
BCSCTL1&=~0X00; //打开XT2振荡器
do
IFG1 &= ~OFIFG; // 清除振荡器失效标志
for (index = 0xFF; index > 0; index--)// 延时,等待XT2起振
} while ((IFG1 & OFIFG) != 0);// 判断XT2是否起振
BCSCTL2 =SELM_2+SELS; //选择MCLK、SMCLK为XT2 SMCLK 8分频
  unsigned long ff,zg;
  uchar j,i;
  uchar ptr[5],ptr2[4];
  ff=8000000/a;
  zg=(b*1000)/a;
  ptr2[0]=zg/100;
  ptr2[1]=zg/10%10;
  ptr2[3]=zg%10;
  ptr2[2]=10;
  if(ff>1000)
    ptr[0]=ff/10000;
    ptr[1]=ff/1000%10;
    ptr[2]=10;
    ptr[3]=ff/100%10;
    ptr[4]=11;
  else
    ptr[0]=ff/100;
    ptr[1]=ff/10%10;
    ptr[2]=ff%10;
    ptr[3]=10;
    ptr[4]=0;
  for(i = 0;i < 4;i++)
    Disp1Char((3 + i),0,shuzi[ptr2[i]]);
  for(j=0;j<5;j++)
    Disp1Char((6 + j),1,shuzi[ptr[j]]);
中断处理函数
#pragma vector=TIMERA1_VECTOR              //定时器A中断处理
__interrupt void timer_a(void)
switch(TAIV)                              //向量查询
  { case 2:                                //捕获中断
       if(CCTL1&CM_1)                      //上升沿
           tem++;
           if(tem==1)
             CCTL1=(CCTL1&(~CM_1))|CM_2;       //更变设置为下降沿触发
             start=TACCR1;                      //记录初始时间
             overflow=0;                     //溢出计数变量复位
           else if(tem==2)
             temp=TACCR1;
             TACTL &=~TAIE;                    //不使能中断
             CCTL1 &=~CCIE;
             P1SEL &=~BIT2;
             _DINT();
             LPM0_EXIT;
       else if(CCTL1&CM_2)                 //下降沿
         CCTL1=(CCTL1&(~CM_2))|CM_0;       //更变设置为上升沿触发
         end=TACCR1;                        //用start,end,overflow计算脉冲宽度
       break;
    case 10:                               //定时器溢出中断
       overflow++;
       break;                              //溢出计数加1
    default:break;
谁能帮俺看看???
kerfier 发表于 2016-10-28 23:19 | 显示全部楼层
描述清楚出什么问题了?
heweibig 发表于 2016-10-28 23:19 | 显示全部楼层
看什么啊?
jiahy 发表于 2016-10-28 23:21 | 显示全部楼层
你可以在上升沿的时候把计数器清0
dengdc 发表于 2016-10-29 22:45 | 显示全部楼层
这样的读数据应该更加精确的。
dengdc 发表于 2016-10-30 18:21 | 显示全部楼层
这个程序不好用呗,读不出来
heweibig 发表于 2016-10-30 18:26 | 显示全部楼层
现在用stm32了,msp这个功能真不常用了。
wuhany 发表于 2016-10-30 18:28 | 显示全部楼层
看着这个程序的需要理一理的:L,关键是中断处理函数的
lizye 发表于 2016-10-30 18:30 | 显示全部楼层
恩啊,不知道为啥,现在好多人喜欢把中断服务程序写得非常长:L
看着就累得慌
spark周 发表于 2016-10-30 18:31 | 显示全部楼层
这句话中的else if  改为if
 楼主| huangchui 发表于 2016-10-30 18:35 | 显示全部楼层
结贴了,多谢大家讨论这么多哈,呵呵
htmlme 发表于 2016-10-30 21:03 | 显示全部楼层
你的捕获PWm吗?
htmlme 发表于 2016-10-30 21:04 | 显示全部楼层
你这是还是例程?
