自制<<手把手教你学单片机C程序设计>>实验板
27591|184
 楼主| gdqinci 发表于 2010-5-2 21:34 | 显示全部楼层
第九章
数**算与显示实验
#include <REG51.H>
#define uchar unsigned char
#define uint unsigned int
uchar code SEG7[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void delay(uint k);
void main(void)
  uchar a,b,c,out;
  a=100;
  b=60;
  c=9;
  out=a+3*(b-c)/2;
  while(1)
     P0=SEG7[out/100];
   P2=0xfb;
   delay(1);
   P0=SEG7[(out%100)/10];
   P2=0xfd;
   delay(1);
   P0=SEG7[out%10];
   P2=0xfe;
   delay(1);
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
 楼主| gdqinci 发表于 2010-5-2 21:35 | 显示全部楼层
输入数的大小比较及判断实验
#include <REG51.H>
uchar a=0,b=0,c;
uchar key_S1(void);
uchar key_S2(void);
void delay(uint k);
void main(void)
uchar i;
while(1)
  b=key_S1();
a=key_S2();
if(a>b)c=0x76;
if(a<b)c=0x38;
if(a==b)c=0x09;
     for(i=0;i<50;i++)
       P0=SEG7[a];
    P2=0xfd;
          delay(2);
          P0=SEG7;
          P2=0xfe;
          delay(2);
          P0=c;
          P2=0xf7;
          delay(2);
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
uchar key_S1(void)
static uchar x;
P3=0xff;
if(P3!=0xff)
   delay(10);
  if(P3==0xfb)
    x=x+1;
if(x>9)x=0;
return x;
uchar key_S2(void)
static uchar y;
P3=0xff;
if(P3!=0xff)
   delay(10);
  if(P3==0xf7)
    y=y+1;
if(y>9)y=0;
return y;
 楼主| gdqinci 发表于 2010-5-2 21:37 | 显示全部楼层
逻辑判断实验
#include <REG51.H>
sbit P3_2=P3^2;
sbit P3_3=P3^3;
uchar data a=0,b=0,out;
uchar key_S1(void);
uchar key_S2(void);
void delay(uint k);
void main(void)
while(1)
   b=key_S1();
  a=key_S2();
  if((a==8)&&(b==5))out=1;
  else out=0;
  P0=SEG7[a];
  P2=0xfd;
  delay(2);
  P0=SEG7;
  P2=0xfe;
  delay(2);
  if(out==1)P0=0x73;
  else P0=0x00;
  P2=0xf7;
  delay(2);
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
uchar key_S1(void)
uchar data x;
P3=0xff;
if(!P3_2)x=5;
else x=0;
return x;
uchar key_S2(void)
uchar data y;
P3=0xff;
if(!P3_3)y=8;
else y=0;
return y;
 楼主| gdqinci 发表于 2010-5-2 21:43 | 显示全部楼层
自增运算a++ 和++b 实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void main(void)
uchar a=0,b=0,i,dis_a,dis_b;
while(1)
      dis_a=SEG7[a++];
   dis_b=SEG7[++b];
   for(i=0;i<250;i++)
     P0=dis_a;
   P2=0xfe;
   delay(2);
   P0=dis_b;
   P2=0xfd;
   delay(2);
   if((a==9)||(b==9))while(1);
 楼主| gdqinci 发表于 2010-5-2 21:44 | 显示全部楼层
两个变量x、y的位运算实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void main(void)
  uchar x=57,y=136;
   P1=~x;
   delay(3000);
   P1=~y;
   delay(3000);
   P1=x&y;
   delay(3000);
   P1=x|y;
   delay(3000);
   P1=x^y;
   delay(3000);
   P1=x<<1;
   delay(3000);
   P1=y<<2;
   delay(3000);
  while(1);
 楼主| gdqinci 发表于 2010-5-2 21:46 | 显示全部楼层
第十章
复合语句实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void main(void)
uchar m=0,n=0,i;
  for(i=0;i<250;i++)
    P0=SEG7[n];
  P2=0xfe;
  delay(4);
  P0=SEG7[m];
  P2=0xfd;
  delay(4);
uchar m=8,x=6;
  for(i=0;i<250;i++)
    P0=SEG7[n];
  P2=0xfe;
  delay(4);
  P0=SEG7[m];
  P2=0xfd;
  delay(4);
  P0=SEG7[x];
  P2=0xfb;
  delay(4);
for(i=0;i<250;i++)
    P0=SEG7[n];
  P2=0xfe;
  delay(4);
  P0=SEG7[m];
  P2=0xfd;
  delay(4);
P0=0x00;
while(1);
 楼主| gdqinci 发表于 2010-5-2 21:47 | 显示全部楼层
条件语句实验一
#include <reg51.h>
sbit KEY_S1=P3^2;
void delay(uint k)
uint i,j;
for(i=0;i<k;i++)
   for(j=0;j<121;j++)
void main(void)
delay(50);
while(1)
  if(!KEY_S1){P1=0x00;}
else {P1=0xff;}
delay(5);
 楼主| gdqinci 发表于 2010-5-2 21:48 | 显示全部楼层
条件语句实验二
#include <REG51.H>
sbit KEY_S1=P3^2;
sbit KEY_S2=P3^3;
sbit KEY_S3=P3^4;
sbit KEY_S4=P3^5;
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void main(void)
  delay(50);
  while(1)
  if(!KEY_S1){P1=0xfc;}
     else if(!KEY_S2){P1=0xf3;}
   else if(!KEY_S3){P1=0xcf;}
    else if(!KEY_S4){P1=0x3f;}
     else {P1=0xff;}
delay(5);
 楼主| gdqinci 发表于 2010-5-2 21:50 | 显示全部楼层
第11章
switch/case 开关语句实验
#include <REG51.H>
uchar ACT[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
uchar status_flag;
uint year;
uchar month;
uchar day;
uchar temp_year_l,temp_month;
uchar temp_year_h;
void key_S1(void);
void key_S2(void);
void key_S4(void);
void delay(uint k);
uchar conv(uint year,uchar month);
void main(void)
uchar i;
uint temp1,temp2;
while(1)
  key_S4();
  switch(status_flag)
   case 0:key_S1();temp1=temp_year_l;
       key_S2();temp2=temp_year_h;break;
   case 1:key_S1();month=temp_month;break;
   default:break;
year=temp1=(temp2*100);
day=conv(year,month);
  for(i=0;i<40;i++)
      switch(status_flag)
       case 0:P0=SEG7[year%10];P2=ACT[4];delay(1);
              P0=SEG7[(year%100)/10];P2=ACT[5];delay(1);
        P0=SEG7[(year/100)%10];P2=ACT[6];delay(1);
        P0=SEG7[year/1000];P2=ACT[7];delay(1);break;
       case 1:P0=SEG7[month%10];P2=ACT[2];delay(2);
        P0=SEG7[month/10];P2=ACT[3];delay(2);break;
       case 2:if(day){P0=SEG7[day%10];P2=ACT[0];delay(2);
                      P0=SEG7[day/10];P2=ACT[1];delay(2);}
        else{P0=0x00;P2=0xff;delay(2);
             P0=0x00;P2=0xff;delay(2);}break;
      default:break;
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void key_S1(void)
P3=0xff;
if(P3==0xfb)
    switch(status_flag)
     case 0:temp_year_l++;
         if(temp_year_l>99)temp_year_l=0;break;
  case 1:temp_month++;
         if(temp_month>12)temp_month=1;break;
  default:break;
void key_S2(void)
P3=0xff;
if(P3==0xf7)
    switch(status_flag)
     case 0:temp_year_h++;
         if(temp_year_h>99)temp_year_h=0;break;
  default:break;
void key_S4(void)
P3=0xff;
if(P3==0xdf)status_flag++;
if(status_flag>2)status_flag=0;
uchar len;
switch(month)
  case 1:len=31;break;
  case 3:len=31;break;
  case 5:len=31;break;
  case 7:len=31;break;
  case 8:len=31;break;
  case 10:len=31;break;
  case 12:len=31;break;
  case 4:len=31;break;
  case 6:len=31;break;
  case 9:len=31;break;
  case 11:len=31;break;
  case 2:if(year%4==0&&year%100!=0||year%400==0)len=29;
   else len=28;break;
  default:return 0;break;
return len;
 楼主| gdqinci 发表于 2010-5-2 21:52 | 显示全部楼层
这个实验的源程序编译可以通过,但是下载到板子以后总是不能正确操作,而且程序本身算法有点让我看不懂。。。。
 楼主| gdqinci 发表于 2010-5-2 21:53 | 显示全部楼层
while语句实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for(i=0;i<k;i++)
   for(j=0;j<121;j++)
void main(void)
uint s,n;
s=0;
n=1;
while(n<=100)
   s=s+n;
   n=n+1;
while(1)
   P0=SEG7[s%10];P2=0xfe;delay(1);
   P0=SEG7[(s%100)/10];P2=0xfd;delay(1);
   P0=SEG7[(s/100)%10];P2=0xfb;delay(1);
   P0=SEG7[s/1000];P2=0xf7;delay(1);
 楼主| gdqinci 发表于 2010-5-2 21:54 | 显示全部楼层
for语句实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for(i=0;i<k;i++)
   for(j=0;j<121;j++)
void main(void)
uint s,sum;
for(s=50;s<=100;s=s+2)
    {sum=sum+s;}
while(1)
    P0=SEG7[sum%10];P2=0xfe;delay(1);
P0=SEG7[(sum%100)/10];P2=0xfd;delay(1);
P0=SEG7[(sum/100)%10];P2=0xfb;delay(1);
P0=SEG7[sum/1000];P2=0xf7;delay(1);
 楼主| gdqinci 发表于 2010-5-2 21:55 | 显示全部楼层
break语句实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for(i=0;i<k;i++)
   for(j=0;j<121;j++)
void main(void)
uchar cnt=0;
P0=SEG7[0];P2=0xfe;
delay(4);
while(1)
    for(cnt=0;cnt<10;cnt++)
      if(cnt>5)break;
   P0=SEG7[cnt];P2=0xfe;
   delay(1000);
 楼主| gdqinci 发表于 2010-5-2 21:56 | 显示全部楼层
continue语句实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for(i=0;i<k;i++)
   for(j=0;j<121;j++)
void main(void)
uchar cnt=0;
P0=SEG7[0];P2=0xfe;
delay(1000);
while(1)
      if(cnt<5)continue;
   delay(1000);
 楼主| gdqinci 发表于 2010-5-2 21:57 | 显示全部楼层
第12章
参数传递的函数调用实验
#include <REG51.H>
sbit P3_2=P3^2;
uchar number1,number2;
void swap(uchar x,uchar y);
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void main(void)
uchar a=3,b=8;
   while(1)
      if(!P3_2)
        swap(a,b);
   P0=SEG7[number1];
   P2=0xfd;
   delay(1);
   P0=SEG7[number2];
   P2=0xfe;
   delay(1);
   else
     number1=a,number2=b;
   P0=SEG7[number1];
   P2=0xfd;
   delay(1);
   P0=SEG7[number2];
   P2=0xfe;
   delay(1);
number1=y;
number2=x;
 楼主| gdqinci 发表于 2010-5-2 21:58 | 显示全部楼层
三个数大小自动排列实验
#include <REG51.H>
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void main(void)
uchar a=3,b=1,c=9;
uchar temp;
if((c>b)&&(c>a))
  temp=c;
  c=a;
  a=temp;
else if((b>a)&&(b>c))
   temp=b;
   b=a;
   a=temp;
if(c>b)
  temp=c;
     c=b;
  b=temp;
while(1)
  P0=SEG7[a];
  P2=0xfb;
  delay(1);
  P0=SEG7;
  P2=0xfd;
  delay(1);
  P0=SEG7[c];
  P2=0xfe;
  delay(1);
 楼主| gdqinci 发表于 2010-5-2 22:00 | 显示全部楼层
华氏-摄氏温度转换的仪器实验
#include <REG51.H>
#include <MATH.H>
uchar code ACT[4]={0xfe,0xfd,0xfb,0xf7};
sbit P3_2=P3^2;
sbit P3_3=P3^3;
sbit P3_5=P3^5;
int c,f;
int temp;
uchar status;
void key_s1(void);
void key_s2(void);
void key_s4(void);
int conv(int fin);
void delay_1ms(void);
void main(void)
int temp_f,temp_c;
while(1)
  key_s1();
  key_s2();
  key_s4();
  if(status==0)
     if(f<0)
        temp_f=abs(f);
        P0=SEG7[temp_f%10];P2=ACT[0];
        delay_1ms();
        P0=SEG7[(temp_f%100)/10];P2=ACT[1];
        delay_1ms();
        P0=SEG7[(temp_f/100)%10];P2=ACT[2];
        delay_1ms();
        P0=0x40;P2=ACT[3];
        delay_1ms();
     else
        P0=SEG7[f%10];P2=ACT[0];
        delay_1ms();
        P0=SEG7[(f%100)/10];P2=ACT[1];
        delay_1ms();
        P0=SEG7[(f/100)%10];P2=ACT[2];
        delay_1ms();
  else
     c=conv(f);
     if(c<0)
        temp_c=abs(c);
        P0=SEG7[temp_c%10];P2=ACT[0];
        delay_1ms();
        P0=SEG7[(temp_c%100)/10];P2=ACT[1];
        delay_1ms();
        P0=SEG7[(temp_c/100)%10];P2=ACT[2];
        delay_1ms();
        P0=0x40;P2=ACT[3];
        delay_1ms();
     else
        P0=SEG7[c%10];P2=ACT[0];
        delay_1ms();
        P0=SEG7[(c%100)/10];P2=ACT[1];
        delay_1ms();
        P0=SEG7[(c/100)%10];P2=ACT[2];
        delay_1ms();
void key_s1(void)
if(!P3_2)
  if(temp>50)temp=0;
if(temp==0)f++;
if(f>999)f=999;
temp++;
void key_s2(void)
if(!P3_3)
  if(temp>50)temp=0;
if(temp==0)f--;
if(f<-500)f=-500;
temp++;
void key_s4(void)
if(!P3_5)status=1;
else status=0;
int conv(int fin)
int ddata;
ddata=fin-32;
ddata=(ddata*5)/9;
return ddata;
uint k;
for(k=0;k<121;k++);
 楼主| gdqinci 发表于 2010-5-2 22:02 | 显示全部楼层
第13章
数组显示实验
#include <REG51.H>
uchar data shuzu[4];
uchar status;
uchar temp,f;
uint k;
for(k=0;k<121;k++);
void dis_all(void)
P0=SEG7[shuzu[0]];P2=ACT[0];
delay_1ms();
P0=SEG7[shuzu[1]];P2=ACT[1];
delay_1ms();
P0=SEG7[shuzu[2]];P2=ACT[2];
delay_1ms();
P0=SEG7[shuzu[3]];P2=ACT[3];
delay_1ms();
void dis_shuzu0(void)
P0=SEG7[f];P2=ACT[0];
delay_1ms();
void dis_shuzu1(void)
P0=SEG7[f];P2=ACT[1];
delay_1ms();
void dis_shuzu2(void)
P0=SEG7[f];P2=ACT[2];
delay_1ms();
void dis_shuzu3(void)
P0=SEG7[f];P2=ACT[3];
delay_1ms();
void key_s1(void)
P3=0xff;
if(P3==0xfb)
   if(temp>50)temp=0;
  if(temp==0)f++;
  if(f>9)f=0;
  temp++;
  delay_1ms();
void key_s2(void)
P3=0xff;
if(P3==0xf7)
   switch(status)
       case 1:shuzu[0]=f;break;
   case 2:shuzu[1]=f;break;
   case 3:shuzu[2]=f;break;
   case 4:shuzu[3]=f;break;
   default:break;
void key_s4(void)
P3=0xff;
if(P3==0xdf)
   if(temp>50)temp=0;
  if(temp==0)status++;
  if(status>4)status=0;
  temp++;
  delay_1ms();
void main()
while(1)
   key_s1();
  key_s2();
  key_s4();
  switch(status)
    case 0:dis_all();break;
    case 1:dis_shuzu0();break;
   case 2:dis_shuzu1();break;
   case 3:dis_shuzu2();break;
   case 4:dis_shuzu3();break;
   default:break;
 楼主| gdqinci 发表于 2010-5-2 22:04 | 显示全部楼层
输入10个整数(0~999之间),输出其中的最大数实验
#include <REG51.H>
uchar code ACT[5]={0xfe,0xfd,0xfb,0xf7,0xef};
uint data shuzu[10];
uchar status;
uchar temp;
int max,f;
uint k;
for(k=0;k<121;k++);
void dis_max(void)
P0=SEG7[max%10];P2=ACT[0];
delay_1ms();
P0=SEG7[(max/10)%10];P2=ACT[1];
delay_1ms();
P0=SEG7[max/100];P2=ACT[2];
delay_1ms();
void dis_input(void)
delay_1ms();
P0=SEG7[(f/10)%10];P2=ACT[1];
delay_1ms();
P0=SEG7[f/100];P2=ACT[2];
delay_1ms();
P0=SEG7[status];P2=ACT[4];
delay_1ms();
void key_s1(void)
P3=0xff;
if(P3==0xfb)
  if(temp>30)temp=0;
  if(temp==0)f++;
  if(f>999)f=999;
  temp++;
  delay_1ms();
void key_s2(void)
P3=0xff;
if(P3==0xf7)
  if(temp>30)temp=0;
  if(temp==0)f--;
  if(f<0)f=0;
  temp++;
  delay_1ms();
void key_s3(void)
  P3=0xff;
  if(P3==0xef)
   switch(status)
    case 0:shuzu[0]=f;break;
case 1:shuzu[1]=f;break;
case 2:shuzu[2]=f;break;
case 3:shuzu[3]=f;break;
case 4:shuzu[4]=f;break;
case 5:shuzu[5]=f;break;
case 6:shuzu[6]=f;break;
case 7:shuzu[7]=f;break;
case 8:shuzu[8]=f;break;
case 9:shuzu[9]=f;break;
default:break;
void key_s4(void)
P3=0xff;
if(P3==0xdf)
  if(temp>100)temp=0;
  if(status>10)status=0;
  temp++;
  delay_1ms();
void conv(void)
uchar i;
max=shuzu[0];
for(i=1;i<10;i++)
   if(shuzu>max)max=shuzu;
void main(void)
while(1)
    key_s1();
key_s2();
key_s3();
key_s4();
conv();
if(status==10)dis_max();
else dis_input();
 楼主| gdqinci 发表于 2010-5-2 22:05 | 显示全部楼层
选择法数组排序显示实验
#include <REG51.H>
sbit KEY_S1=P3^2;
uint data a[10]={23,58,123,54,63,589,888,19,333,220};
void delay(uint k)
uint i,j;
for (i=0;i<k;i++)
    for (j=0;j<121;j++)
void sort(uint array[],uint n)
uint i,j,k,t;
for(i=0;i<n-1;i++)
  k=i;
  for(j=i+1;j<n;j++)
      if(array[j]<array[k])k=j;
  t=array[k];
  array[k]=array;
  array=t;
void dis(uint array[],uint n)
uint m,t;
for(m=0;m<n;m++)
  for(t=0;t<300;t++)
    P0=SEG7[array[m]%10];
    P2=ACT[0];
    delay(2);
    P0=SEG7[(array[m]/10)%10];
    P2=ACT[1];
    delay(2);
    P0=SEG7[array[m]/100];
    P2=ACT[2];
    delay(2);
    P0=SEG7[m];
    P2=ACT[4];
    delay(2);
void main(void)
  while(1)
   dis(a,10);
   while(KEY_S1);
   sort(a,10);
   dis(a,10);
   while(1);
