用F2812烧写时出现下面这个问题,不知怎么回事
3226|0
redgalaxy|  楼主 | 2010-3-29 14:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
要是打开CCS后,过一会烧写还可以,但是如果隔一段时间比如五六分钟再烧写,就会出现如下问题,必须关闭电源和CCS重新打开后才可以,哪位高人给指点一下,谢谢!
Non-supported Part ID:0x0bad
                      Only F28XX (Part ID 0x0001/2),F2801 (Part ID 0x002c),
                      F2806 (Part ID 0x0034),F2808 (Part ID 0x003c),
                      F2802 (Part ID 0x0024) devices are supported.
                      However,the PartID register
                      may not have been read properly due to the target
                      state.
                      Please reset the DSP and try again.
