[i.MX] ubuntu12.04上ltib编译问题
926|1
 楼主| zgs9199591995 发表于 2016-11-10 11:18 | 显示全部楼层 |阅读模式
ubuntu12.04编译ltib出现一下问题
     2  Processing platform: host support
     3  ===================================
     5  Processing: rpm-fs
     6  ====================
     7  ERROR: /tmp/rpm-linux/RPMS/i686/rpm-fs-4.0.4-1.i686.rpm
     8  would clobber '/reescale/ltib'
     9  traceback:
    10   main::check_host_clobber:2693
    11    main::build_rpm:918
    12     main::f_buildrpms:992
    13      main::check_rpm_setup:2424
    14       main::host_checks:1435
    15        main:554
    16
    17
    18  Started: Thu Nov 10 11:12:33 2016
    19  Ended:   Thu Nov 10 11:12:33 2016
    20  Elapsed: 0 seconds
    21
    22
    23  Build Failed
    24
