求助DM642+CCS5.5 Build通过Debug报错
972|6
 楼主| Varus 发表于 2016-11-22 21:08 | 显示全部楼层 |阅读模式
在编译完成一个工程后Debug时老是会报错:
不管是重启CCS,插拔板子和仿真器(XDS100V2或XDS560V2)总是报以下错误,仅有一次运行成功,程序可正常运行,不知道是CCS设置问题,程序问题还是硬件问题,跪求大神解答。。。
C64x: Error: (Error -2044 @ 0xDD8) Internal error: Requested breakpoint does not exist. Restart the application. If error persists, please report the error. (Emulation package 5.1.232.0)
C64x: Unable to determine target status after 20 attempts
C64x: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
lefeng 发表于 2016-11-22 21:20 | 显示全部楼层
把程序中的断点去掉试试
拉克丝 发表于 2016-11-22 21:31 | 显示全部楼层
这是哪里的断点没有删掉吧
Snow7 发表于 2016-11-22 22:04 | 显示全部楼层
这个断点问题怎么解决的,我调试也是总是报错C64x: Breakpoint Manager: Retrying with a AET breakpoint
C64x: Trouble Setting Breakpoint with the Action "Finish Auto Run" at 0x80372df4: (Error -1066 @ 0x80372DF4) Unable to set requested breakpoint in memory. Verify that the breakpoint address is in writable memory. (Emulation package 5.0.747.0)
zhangmangui 发表于 2016-11-22 22:24 | 显示全部楼层
好像跟程序中设置的断点有关   但是这个应该只会是一个警告
不至于功能不正常
isseed 发表于 2016-11-23 22:36 | 显示全部楼层
是不是软件兼容性不好
isseed 发表于 2016-11-23 22:37 | 显示全部楼层
重新复位开发板的电路
