求助,485发出不管什么数,都收为00
2547|2
 楼主| chengli 发表于 2010-3-31 17:53 | 显示全部楼层 |阅读模式
用PIC18,用示波器看了,是有0x55出来,不知怎么搞的
10MHzFosc,HS-PLL,4所以,40MHz
SYNC = 0, BRGH = 0, BRG16 = 0
void main (void)
unsigned char str[10]={1,2,3,4,5,6,7,8,9,0};
  /* Make all bits on the Port B (LEDs) output bits.
   * If bit is cleared, then the bit is an output bit.
SPBRG2 = 0x19;
TXSTA2 = 0x24;
TRISB = 0;
    //delay ();
//禁止发送中断 禁止接收中断 异步模式 8 位发送/ 接收 连续接收 低波特率
Open2USART( USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_LOW,15 );
LATG &= ~0x18;//485 DE,/R/E
PORTG &= ~0x18;
TRISG &= ~0x18;
LATG |=  0x18;//DE Enable
// PORTG &= ~0x08;//DE Enable
// PORTG &= ~0x10;
  while (1)
      /* Reset the LEDs */
  //    PORTB = 0;
      /* Delay so human eye can see change */
// puts2USART( str ); // print string
  Write2USART( 0x55 ); //write value of PORTD
      /* Light the LEDs */
//     PORTB = 0x5A;
       delay ();
 楼主| chengli 发表于 2010-3-31 18:28 | 显示全部楼层
BAUDCON2 &= ~0x08;
        Open2USART( USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_LOW,0x40 );
 楼主| chengli 发表于 2010-3-31 18:45 | 显示全部楼层
找到原因了
#include <p18cxxx.h>
#include <p18F6722.h>
#include <usart.h>
#include <stdlib.h>
去掉p18cxxx就好了
