[技术求助] 仿真器连接不上,CCS5.4使用XDS510,测试连接时显示失败
1673|2
 楼主| lysh1992 发表于 2016-11-26 13:31 | 显示全部楼层 |阅读模式
Failure due to the controller command-finish taking too long.
[Start]
Execute the command:
%ccs_base%/common/uscif/dbgjtag.exe -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\lysh1992\AppData\Local\.TI\693494126\
    0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'seedjca8990isa.dll'.
The library build date was 'Apr  1 2013'.
The library build time was '23:55:08'.
The library package version is '5.1.73.0'.
The library component version is '35.34.40.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '1' (0x00000001).
The controller has an insertion length of '16' (0x00000010).
This utility will attempt to reset the controller.
A error occurred while attempting to reset the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-342' (0xfffffeaa).
The title is 'SC_ERR_HUNG_COMMAND'.
The explanation is:
[End]
airwill 发表于 2016-11-27 07:31 | 显示全部楼层
初步判断是连接问题, 检查一下仿真器和芯片之间的连接, 特别是那条 NRST 线是不是有问题?
smilingangel 发表于 2016-11-27 12:18 | 显示全部楼层
这个先检查下硬件上的设计的吧
