[PIC®/AVR®/dsPIC®产品] PIC中断接收的问题,如果不加入写函数,都正常
717|0
 楼主| thefox 发表于 2016-12-5 16:07 | 显示全部楼层 |阅读模式
中断接收函数
uint8_t rx_recv(uint8_t byt_e)
    uint8_t i = 0;
    rx.temp = byt_e ;
    if((head_info.step == 0) && (byt_e == 0x2C))
        head_info.cnt = 0;
    if(head_info.cnt < 4)
        head_info.head[head_info.cnt++] = byt_e;
    if(head_info.cnt >= 4)
        if((head_info.head[0] == 0x2C ) &&
           (head_info.head[1] == 0x2F ) &&
           (head_info.head[2] == 0x3B ) &&
           (head_info.head[3] == 0x27 ))
            head_info.step = 1;
            rx.State = 1 ;
            //rx_recv1(byt_e);
        else
            head_info.cnt = 0;
    return rx.temp ;
uint8_t rx_recv1(uint8_t byt_e)
    if(rx.W_pos >= 252)
        rx.W_pos=0;
        rx.RecieveFlag = 1;
    else
        rx.RecieveFlag = 0;
    rx.data[rx.W_pos] = byt_e ;
    rx.Gettotalnumber += 1 ;
    if(rx.W_pos < 255)
        rx.W_pos++;
     //= byt_e ;
    if(rx.W_pos>=7)
        if( rx.data[rx.W_pos-1]==0x3b  )
            rx.Getdata_Over_flag = 4 ;
            if(rx.data[rx.W_pos-2]==0x2c)
                rx.Getdata_Over_flag = 3 ;
                if(rx.data[rx.W_pos-3]==0x27)
                    rx.Getdata_Over_flag = 2 ;
                    if(rx.data[rx.W_pos-4]==0x2f)
                        rx.Getdata_Over_flag = 1 ;
                        rx.RecieveFlag = 1 ;
中断
void __attribute__ ( ( interrupt, no_auto_psv ) ) _U2RXInterrupt( void )
    uint8_t b_yte;;
    int count = 0;
#if 1
    b_yte = U2RXREG;
    if(rx.State == 1)
        rx_recv1(b_yte);
    else
        rx_recv(b_yte);
    IFS1bits.U2RXIF = false;
写函数
uint8_t Flash_WritePack(uint16_t addresss,uint16_t *data,uint16_t len)
    uint8_t flag = 0;
    uint16_t j,i,page_num,word_num;
    flag = FlashErasePage(addresss);
    page_num = len/LEN_LEN;
    word_num = len%LEN_LEN;
    NVMCON = PM_ROW_WRITE;//0x4001;
    TBLPAG = 0;
    i=0;
    while(page_num>0)
        for(;i<len;i++)
            __builtin_tblwtl(addresss,(*(data + i)));
            addresss +=2;
            if((i+1)%LEN_LEN == 0)
                i += 1;
                break;
        __builtin_disi(5); //  Disable interrupts for NVM unlock sequence
        NVMKEY = 0x55;
        NVMKEY = 0xaa;
        __builtin_write_NVM(); // initiate write
        Nop();
        Nop();
        //Flash_TmCnt.cnt = 0;
        //asm("DISI #0X0000");        //ensure intterupt is closed
        while(NVMCONbits.WR)
            break;
        if(flag == 1)
            break;
        page_num--;
    if(flag == 0)
        TBLPAG = 0;
        for(j=0;j<word_num;j++)
            Flash_WriteWords(addresss,*(data + i));
            addresss +=2;
            i +=1;
    return flag;
