FPGA选型资源大些做算法就是爽
1594|2
 楼主| feihufuture 发表于 2016-12-8 09:11 | 显示全部楼层 |阅读模式
polun 发表于 2016-12-8 11:48 | 显示全部楼层
大神你就这样结贴了 标题党呀
sxp566 发表于 2016-12-8 16:05 | 显示全部楼层
Total combinational functions        42,961 / 55,856 ( 77 % )        Flow Status        Analyzed - Wed Jul 06 14:57:23 2016
Dedicated logic registers        23,698 / 55,856 ( 42 % )        Quartus II 64-Bit Version        10.1 Build 197 01/19/2011 SP 1 SJ Full Version
Revision Name        APF_3level_V8_50A_V32
Top-level Entity Name        APF_3level_V8_100A_V32
Family        Cyclone III
Device        EP3C55F484C6
Timing Models        Final
Total logic elements        51,705 / 55,856 ( 93 % )
Total registers        23769
Total pins        201 / 328 ( 61 % )
Total virtual pins        0
Total memory bits        68,248 / 2,396,160 ( 3 % )
Embedded Multiplier 9-bit elements        42 / 312 ( 13 % )
Total PLLs        1 / 4 ( 25 % )
个人签名:WX:feihu612 免费合作开发ECAT主从站
171
