ESP-mp-01开发板SPI驱动OLED显示
1176|2
hbzjt2011|  楼主 | 2016-12-14 11:01 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
       昨天使用ESP-mp-01开发板的I2C成功驱动OLED显示,今天测试了SPI方式,同样成功点亮OLED。
【1】硬件连接:
ESP8266 SPI对应的引脚为Pin(14)--SCK,Pin(13)--MOSI,Pin(12)--MISO,Pin(16)--CS:
【2】程序源码:
# main.py -- put your code here!
import machine
from machine import Pin,I2C,SPI
import ssd1306
import math
import time
# construct an I2C bus
#i2c = I2C(scl=Pin(14), sda=Pin(2), freq=100000)
#display = ssd1306.SSD1306_I2C(128,64, i2c)
# construct an SPI bus on the given pins
# polarity is the idle state of SCK
# phase=0 means sample on the first edge of SCK, phase=1 means the second
spi = SPI(baudrate=10000000, polarity=1, phase=0, sck=Pin(14,Pin.OUT), mosi=Pin(13,Pin.OUT), miso=Pin(12))
display = ssd1306.SSD1306_SPI(128, 64, spi, Pin(5),Pin(4), Pin(16))
led_blue = machine.Pin(2, Pin.OUT) # 设置 GPIO2 为输出
led_blue.high()
try:
display.poweron()
display.init_display()
display.text('ESP-mp SPI OLED',1,1)
display.text('Hi, MicroPython!',1,16)
display.text('By: hbzjt2012',1,31)
# Write display buffer
display.show()
time.sleep(3)
display.fill(0)
for x in range(0, 128):
display.pixel(x, 32+int(math.sin(x/64*math.pi)*7 + 8), 1)
display.show()
time.sleep(3)
display.fill(0)
x = 0
y = 0
direction_x = True
direction_y = True
while True:
# Clear the previous lines
prev_x = x
prev_y = y
# Move bars
x += (1 if direction_x else -1)
y += (1 if direction_y else -1)
# Bounce back, if required
if x == 128:
direction_x = False
x = 126
elif x == -1:
direction_x = True
x = 1
if y == 64:
direction_y = False
y = 63
elif y == -1:
direction_y = True
y = 1
# Draw new lines
for i in range(64):
display.pixel(prev_x, i, False)
display.pixel(x, i, True)
for i in range(128):
display.pixel(i, prev_y, False)
display.pixel(i, y, True)
# Make sure the corners are active
display.pixel(0, 0, True)
display.pixel(127, 0, True)
display.pixel(0, 63, True)
display.pixel(127, 63, True)
display.show()
except Exception as ex:
led_blue.low()
print('Unexpected error: {0}'.format(ex))
display.poweroff()
【3】效果演示:
zhanzr21| | 2016-12-15 01:01 | 只看该作者
好,支持!
phlr| | 2016-12-20 14:48 | 只看该作者
支持一下!
个人签名:欢迎参与LabVIEW版块的讨论学习! 点我一键即达
157
