- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V3.00
- * $Revision: 2 $
- * $Date: 14/12/25 10:24a $
- * @brief
- * Show a Master how to access Slave.
- * This sample code needs to work with I2C_Slave.
- * @note
- * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "M0518.h"
- #define PLLCON_SETTING SYSCLK_PLLCON_50MHz_XTAL
- #define PLL_CLOCK 50000000
- /* Global variables */
- volatile uint8_t g_u8DeviceAddr;
- volatile uint8_t g_au8TxData[3];
- volatile uint8_t g_u8RxData;
- volatile uint8_t g_u8DataLen;
- volatile uint8_t g_u8EndFlag = 0;
- typedef void (*I2C_FUNC)(uint32_t u32Status);
- static volatile I2C_FUNC s_I2C0HandlerFn = NULL;
- /* I2C0 IRQ Handler */
- void I2C0_IRQHandler(void)
- uint32_t u32Status;
- u32Status = I2C_GET_STATUS(I2C0);
- if(I2C_GET_TIMEOUT_FLAG(I2C0))
- /* Clear I2C0 Timeout Flag */
- I2C_ClearTimeoutFlag(I2C0);
- else
- if(s_I2C0HandlerFn != NULL)
- s_I2C0HandlerFn(u32Status);
- /* I2C Rx Callback Function */
- void I2C_MasterRx(uint32_t u32Status)
- if(u32Status == 0x08) /* START has been transmitted and prepare SLA+W */
- I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1)); /* Write SLA+W to Register I2CDAT */
- I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
- else if(u32Status == 0x18) /* SLA+W has been transmitted and ACK has been received */
- I2C_SET_DATA(I2C0, g_au8TxData[g_u8DataLen++]);
- else if(u32Status == 0x20) /* SLA+W has been transmitted and NACK has been received */
- I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_STO_SI);
- else if(u32Status == 0x28) /* DATA has been transmitted and ACK has been received */
- if(g_u8DataLen != 2)
- else
- I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_SI);
- else if(u32Status == 0x10) /* Repeat START has been transmitted and prepare SLA+R */
- I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01)); /* Write SLA+R to Register I2CDAT */
- else if(u32Status == 0x40) /* SLA+R has been transmitted and ACK has been received */
- else if(u32Status == 0x58) /* DATA has been received and NACK has been returned */
- g_u8RxData = (unsigned char) I2C_GET_DATA(I2C0);
- I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
- g_u8EndFlag = 1;
- else
- /* TO DO */
- printf("Status 0x%x is NOT processed\n", u32Status);
- /* I2C Tx Callback Function */
- void I2C_MasterTx(uint32_t u32Status)
- if(u32Status == 0x08) /* START has been transmitted */
- I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1); /* Write SLA+W to Register I2CDAT */
- if(g_u8DataLen != 3)
- else
- g_u8EndFlag = 1;
- else
- /* TO DO */
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable Internal RC 22.1184MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
- /* Waiting for Internal RC clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
- /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
- /* Enable external XTAL 12MHz clock */
- CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
- /* Waiting for external XTAL clock ready */
- CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
- /* Set core clock as PLL_CLOCK from PLL */
- CLK_SetCoreClock(PLL_CLOCK);
- /* Enable UART module clock */
- CLK_EnableModuleClock(UART0_MODULE);
- /* Enable I2C0 module clock */
- CLK_EnableModuleClock(I2C0_MODULE);
- /* Select UART module clock source */
- CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
- /* Init I/O Multi-function */
- /* Set GPB multi-function pins for UART0 RXD and TXD */
- SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
- /* Set GPA multi-function pins for I2C0 SDA and SCL */
- SYS->GPA_MFP = SYS_GPA_MFP_PA8_I2C0_SDA | SYS_GPA_MFP_PA9_I2C0_SCL;
- void UART0_Init()
- /* Init UART */
- /* Reset IP */
- SYS_ResetModule(UART0_RST);
- /* Configure UART0 and set UART0 Baudrate */
- UART_Open(UART0, 115200);
- void I2C0_Init(void)
- /* Open I2C module and set bus clock */
- I2C_Open(I2C0, 100000);
- /* Get I2C0 Bus Clock */
- printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
- /* Set I2C 4 Slave Addresses */
- I2C_SetSlaveAddr(I2C0, 0, 0x15, 0); /* Slave Address : 0x15 */
- I2C_SetSlaveAddr(I2C0, 1, 0x35, 0); /* Slave Address : 0x35 */
- I2C_SetSlaveAddr(I2C0, 2, 0x55, 0); /* Slave Address : 0x55 */
- I2C_SetSlaveAddr(I2C0, 3, 0x75, 0); /* Slave Address : 0x75 */
- /* Enable I2C interrupt */
- I2C_EnableInt(I2C0);
- NVIC_EnableIRQ(I2C0_IRQn);
- void I2C0_Close(void)
- /* Disable I2C0 interrupt and clear corresponding NVIC bit */
- I2C_DisableInt(I2C0);
- NVIC_DisableIRQ(I2C0_IRQn);
- /* Disable I2C0 and close I2C0 clock */
- I2C_Close(I2C0);
- CLK_DisableModuleClock(I2C0_MODULE);
- int32_t I2C0_Read_Write_SLAVE(uint8_t slvaddr)
- uint32_t i;
- g_u8DeviceAddr = slvaddr;
- for(i = 0; i < 0x100; i++)
- g_au8TxData[0] = (uint8_t)((i & 0xFF00) >> 8);
- g_au8TxData[1] = (uint8_t)(i & 0x00FF);
- g_au8TxData[2] = (uint8_t)(g_au8TxData[1] + 3);
- g_u8DataLen = 0;
- g_u8EndFlag = 0;
- /* I2C function to write data to slave */
- s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
- /* I2C as master sends START signal */
- I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
- /* Wait I2C Tx Finish */
- while(g_u8EndFlag == 0);
- g_u8EndFlag = 0;
- /* I2C function to read data from slave */
- s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterRx;
- g_u8DataLen = 0;
- /* Wait I2C Rx Finish */
- /* Compare data */
- if(g_u8RxData != g_au8TxData[2])
- printf("I2C Byte Write/Read Failed, Data 0x%x\n", g_u8RxData);
- return -1;
- printf("Master Access Slave (0x%X) Test OK\n", slvaddr);
- return 0;
- /* Main Function */
- int32_t main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Init UART0 for printf */
- UART0_Init();
- /* Lock protected registers */
- SYS_LockReg();
- This sample code sets I2C bus clock to 100kHz. Then, Master accesses Slave with Byte Write
- and Byte Read operations, and check if the read data is equal to the programmed data.
- printf("\n");
- printf("+--------------------------------------------------------+\n");
- printf("| M0518 I2C Driver Sample Code(Master) for access Slave |\n");
- printf("| |\n");
- printf("| I2C Master (I2C0) <---> I2C Slave(I2C0) |\n");
- printf("Configure I2C0 as a master.\n");
- printf("The I/O connection for I2C0:\n");
- printf("I2C0_SDA(PA.8), I2C0_SCL(PA.9)\n");
- /* Init I2C0 */
- I2C0_Init();
- printf("\n");
- printf("Check I2C Slave(I2C0) is running first!\n");
- printf("Press any key to continue.\n");
- getchar();
- /* Access Slave with no address */
- printf("\n");
- printf(" == No Mask Address ==\n");
- I2C0_Read_Write_SLAVE(0x15);
- I2C0_Read_Write_SLAVE(0x35);
- I2C0_Read_Write_SLAVE(0x55);
- I2C0_Read_Write_SLAVE(0x75);
- printf("SLAVE Address test OK.\n");
- /* Access Slave with address mask */
- printf("\n");
- printf(" == Mask Address ==\n");
- I2C0_Read_Write_SLAVE(0x15 & ~0x01);
- I2C0_Read_Write_SLAVE(0x35 & ~0x04);
- I2C0_Read_Write_SLAVE(0x55 & ~0x01);
- I2C0_Read_Write_SLAVE(0x75 & ~0x04);
- printf("SLAVE Address Mask test OK.\n");
- s_I2C0HandlerFn = NULL;
- /* Close I2C0 */
- I2C0_Close();
- return 0;
