[i.MX] i.MX6 Ubuntu16.04上编译LTIB 遇到的问题
2145|2
 楼主| testbit245 发表于 2016-12-24 10:55 | 显示全部楼层 |阅读模式
L3.0.35_4.1.0_130816_source解压安装后,按步骤要求安装:   ./ltib命令但是终端有错误如下:
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/(%{ <-- HERE ?([^}]+)}?)/ at /home/sicong/fsl/ltib/bin/Ltibutils.pm line 237.
Can't use 'defined(@array)' (Maybe you should just omit the defined()?) at /home/sicong/fsl/ltib/bin/Ltibutils.pm line 362.
Compilation failed in require at ./ltib line 39.
BEGIN failed--compilation aborted at ./ltib line 39.
对对对0 发表于 2017-5-25 20:20 | 显示全部楼层
你好,问题解决了么,我也同样遇到了
tengjiehuang 发表于 2017-7-3 11:53 | 显示全部楼层
我也是,后来换了14.04再打补丁就行了
