 -  * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
 -  * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
 -  * $Revision: 4 $
 -  * $Date: 15/05/18 4:22p $
 -  * [url=home.php?mod=space&uid=247401]@brief[/url]    NUC230_240 Series I2C Driver Sample Code for EEPROM 24LC64
 -  * @note
 -  * Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
 - #include <stdio.h>
 - #include "NUC230_240.h"
- #define PLLCON_SETTING      CLK_PLLCON_72MHz_HXT
 - #define PLL_CLOCK           72000000
 - /* Global variables        */
 - volatile uint8_t g_u8DeviceAddr;
 - volatile uint8_t g_au8TxData[3];
 - volatile uint8_t g_u8RxData;
 - volatile uint8_t temp;
 - volatile uint8_t g_u8DataLen;
 - volatile uint8_t g_u8EndFlag = 0;
- typedef void (*I2C_FUNC)(uint32_t u32Status);
- static I2C_FUNC s_I2C0HandlerFn = NULL;
 - /*  I2C0 IRQ Handler        */
 - void I2C0_IRQHandler(void)
 -     uint32_t u32Status;
-     u32Status = I2C_GET_STATUS(I2C0);
 -     if(I2C_GET_TIMEOUT_FLAG(I2C0))
 -         /* Clear I2C0 Timeout Flag */
 -         I2C_ClearTimeoutFlag(I2C0);
 -     else
 -         if(s_I2C0HandlerFn != NULL)
 -             s_I2C0HandlerFn(u32Status);
 - /*  I2C Rx Callback Function        */
 - void I2C_MasterRx(uint32_t u32Status)
 -     if(u32Status == 0x08)                       /* START has been transmitted and prepare SLA+W */
 -         I2C_SET_DATA(I2C0, (g_u8DeviceAddr << 1));    /* Write SLA+W to Register I2CDAT */
 -         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_SI);
 -     else if(u32Status == 0x18)                  /* SLA+W has been transmitted and ACK has been received */
 -         I2C_SET_DATA(I2C0, g_au8TxData[g_u8DataLen++]);
 -     else if(u32Status == 0x20)                  /* SLA+W has been transmitted and NACK has been received */
 -         I2C_STOP(I2C0);
 -         I2C_START(I2C0);
 -     else if(u32Status == 0x28)                  /* DATA has been transmitted and ACK has been received */
 -         if(g_u8DataLen != 1)
 -         else
 -             I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA_SI);
 -     else if(u32Status == 0x10)                  /* Repeat START has been transmitted and prepare SLA+R */
 -         I2C_SET_DATA(I2C0, ((g_u8DeviceAddr << 1) | 0x01));   /* Write SLA+R to Register I2CDAT */
 -     else if(u32Status == 0x40)                  /* SLA+R has been transmitted and ACK has been received */
 -     else if(u32Status == 0x58)                  /* DATA has been received and NACK has been returned */
 -         g_u8RxData = (unsigned char) I2C_GET_DATA(I2C0);
 -         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STO_SI);
 -         g_u8EndFlag = 1;
 -     else
 -         /* TO DO */
 -         printf("Status 0x%x is NOT processed\n", u32Status);
 - /*  I2C Tx Callback Function        */
 - void I2C_MasterTx(uint32_t u32Status)
 -     if(u32Status == 0x08)                       /* START has been transmitted */
 -         I2C_SET_DATA(I2C0, g_u8DeviceAddr << 1);    /* Write SLA+W to Register I2CDAT */
 -         I2C_STOP(I2C0);
 -         I2C_START(I2C0);
 -         if(g_u8DataLen != 2)
 -         else
 -             g_u8EndFlag = 1;
 -     else
 -         /* TO DO */
- void SYS_Init(void)
 -     /* Init System Clock        */
-     /* Enable Internal RC 22.1184MHz clock */
 -     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
-     /* Waiting for Internal RC clock ready */
 -     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
-     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
 -     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
-     /* Enable external XTAL 12MHz clock */
 -     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
-     /* Waiting for external XTAL clock ready */
 -     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
-     /* Set core clock as PLL_CLOCK from PLL */
 -     CLK_SetCoreClock(PLL_CLOCK);
-     /* Enable UART module clock */
 -     CLK_EnableModuleClock(UART0_MODULE);
-     /* Enable I2C0 module clock */
 -     CLK_EnableModuleClock(I2C0_MODULE);
-     /* Select UART module clock source */
 -     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
 -     /* Init I/O Multi-function        */
-     /* Set GPB multi-function pins for UART0 RXD and TXD */
 -     SYS->GPB_MFP = SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD;
-     /* Set GPA multi-function pins for I2C0 SDA and SCL */
 -     SYS->GPA_MFP = SYS_GPA_MFP_PA8_I2C0_SDA | SYS_GPA_MFP_PA9_I2C0_SCL;
- void UART0_Init()
 -     /* Init UART        */
 -     /* Reset IP */
 -     SYS_ResetModule(UART0_RST);
-     /* Configure UART0 and set UART0 Baudrate */
 -     UART_Open(UART0, 115200);
- void I2C0_Close(void)
 -     /* Disable I2C0 interrupt and clear corresponding NVIC bit */
 -     I2C_DisableInt(I2C0);
 -     NVIC_DisableIRQ(I2C0_IRQn);
-     /* Disable I2C0 and close I2C0 clock */
 -     I2C_Close(I2C0);
 -     CLK_DisableModuleClock(I2C0_MODULE);
- void I2C0_Init(void)
 -     /* Open I2C module and set bus clock */
 -     I2C_Open(I2C0, 100000);
-     /* Get I2C0 Bus Clock */
 -     printf("I2C clock %d Hz\n", I2C_GetBusClockFreq(I2C0));
-     /* Enable I2C interrupt */
 -     I2C_EnableInt(I2C0);
 -     NVIC_EnableIRQ(I2C0_IRQn);
- uint8_t dec_to_bcd(int dec)
 -         uint8_t bcd=((dec / 10) << 4) | (dec % 10);
 -   return bcd;
- int bcd_to_dec(uint8_t hex)
 -     int dec = ((hex & 0xF0) >> 4) * 10 + (hex & 0x0F);
 -     return dec;
- unsigned char DS3231_RTC_Read(unsigned char reg)
 -  g_u8DeviceAddr = 0x68;
-  g_au8TxData[0] = reg; //register
-  g_u8DataLen = 0;
 -         g_u8EndFlag = 0;
-         /* I2C function to write data to slave */
 -         s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterRx;
-         /* I2C as master sends START signal */
 -         I2C_SET_CONTROL_REG(I2C0, I2C_I2CON_STA);
-         /* Wait I2C Tx Finish */
 -         while(g_u8EndFlag == 0);
 -         g_u8EndFlag = 0;
- return bcd_to_dec(g_u8RxData);
- void DS3231_RTC_Write(unsigned char reg,unsigned char value)
 -  g_au8TxData[1] = dec_to_bcd(value); //value
 -  g_u8DataLen = 0;
 -         g_u8EndFlag = 0;
 -         s_I2C0HandlerFn = (I2C_FUNC)I2C_MasterTx;
 -         g_u8EndFlag = 0;
 - #define Seconds 0x00
 - #define Miutes 0x01
 - #define Hours   0x02
 - #define Day     0x03
 - #define Date     0x04
 - #define Month     0x05
 - #define Year     0x06
 - /*  Main Function        */
 - int32_t main(void)
- unsigned char Seconds_temp;
 -     /* Unlock protected registers */
 -     SYS_UnlockReg();
-     /* Init System, IP clock and multi-function I/O */
 -     SYS_Init();
-     /* Lock protected registers */
 -     SYS_LockReg();
-     /* Init UART0 for printf */
 -     UART0_Init();
 -         This sample code sets I2C bus clock to 100kHz. Then, accesses EEPROM 24LC64 with Byte Write
 -         and Byte Read operations, and check if the read data is equal to the programmed data.
-     printf("+------------------------------------------------------------+\n");
 -     printf("|    NUC230_240 I2C Driver Sample Code with DS3231    |\n");
-     /* Init I2C0 to access EEPROM */
 -     I2C0_Init();
-        DS3231_RTC_Write(Hours,01);
 -                          DS3231_RTC_Write(Miutes,01);
 -                          DS3231_RTC_Write(Seconds,01);
- while(1)
 -   if(Seconds_temp!=DS3231_RTC_Read(Seconds))
 -                 Seconds_temp=DS3231_RTC_Read(Seconds);
 -                 printf("%d: ",DS3231_RTC_Read(Hours));
 -           printf("%d: ",DS3231_RTC_Read(Miutes));
 -     printf("%d\n\r",Seconds_temp);
