收藏0 举报
huangcunxiake 发表于 2016-12-27 16:47 楼主可以找到这个芯片的例程看看,官方有的
/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technology Corp. // E-mail: MicroC-8bit@nuvoton.com //*********************************************************************************************************** // Application: LDROM program Data Flash Function // ISP_LD.bin need to program to LD // Config0 bit7(CBS) need to select LDROM // // Output : Test OK => P0 = 0 // Erase Data Verify err => P0 = ~0xA1 // Program Data Verify err => P0 = ~0xA2 // // Because ICE bridge can't update LDROM, Please using ICP/HW writer to update LDROM. //*********************************************************************************************************** //------------------------- <<< Use Configuration Wizard in Context Menu >>> -------------------------------- // <h> UART pin Select // <o0.6> UART pin // <0=> Select P1.0, P1.1 as UART pin(default) // <1=> Select P2.6, P2.7 as UART pin(28 pin only) // </h> //-------------------------------- <<< end of configuration section >>> ------------------------------------- #define Uart_Port_Sel 0x00 #include "N79E715.h" #include "Typedef.h" #include "Define.h" #include "Common.h" #include "Delay.h" #include "Version.h" #include <intrins.h> #include <stdio.h> #include <string.h> #define ERASE_ALL_DATA 0x22 #define FLASH_READ_DATA 0x00 #define BYTE_PROGRAM_DATA 0x21 #define ERASE_ALL_CONFIG 0xE2 #define FLASH_READ_CONFIG 0xC0 #define BYTE_PROGRAM_CONFIG 0xE1 bit EA_Save_bit; //----------------------------------------------------------------------------------------------------------- void Clear_BOF(void) { EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; PMCR &= CLR_BIT3; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Enable_ISP_Mode(void) { /* Enable ISP */ EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; CHPCON |= 0x01; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Disable_ISP_Mode(void) { /* Disable ISP */ EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; CHPCON &= 0xFE; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Trigger_ISP(void) { EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; ISPTRG |= 0x01; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Erase_DATA(void) { UINT16 u16Count; Enable_ISP_Mode(); P0 = ~0x01; ISPCN = ERASE_ALL_DATA; for(u16Count=96;u16Count<128;u16Count++) { ISPAL = LOBYTE(u16Count*128); // 96*128=12288=0x3000 ISPAH = HIBYTE(u16Count*128); // 96*128=12288=0x3000 Trigger_ISP(); } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Erase_DATA_Verify(void) { UINT16 u16Count; Enable_ISP_Mode(); P0 = ~0x02; ISPAL = 0x00; ISPAH = 0x30; ISPCN = FLASH_READ_DATA; for(u16Count=12288;u16Count<16384;u16Count++) { ISPFD = 0; Trigger_ISP(); if(ISPFD != 0xFF) { printf ("\nEV err."); P0 = ~0xA1; while(1); } ISPAL++; if(ISPAL == 0) { ISPAH++; } } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Program_DATA(void) { UINT16 u16Count; Enable_ISP_Mode(); P0 = ~0x03; ISPAL = 0x00; ISPAH = 0x30; ISPFD = 0xFF; ISPCN = BYTE_PROGRAM_DATA; for(u16Count=12288;u16Count<16384;u16Count++) { ISPFD++; Trigger_ISP(); ISPAL++; if(ISPAL == 0) { ISPAH++; } } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Program_DATA_Verify(void) { UINT16 u16Count; UINT8 u8Read_Data; Enable_ISP_Mode(); P0 = ~0x04; ISPAL = 0x00; ISPAH = 0x30; u8Read_Data = 0x00; ISPCN = FLASH_READ_DATA; for(u16Count=12288;u16Count<16384;u16Count++) { Trigger_ISP(); if(ISPFD != u8Read_Data) { printf ("\nPV err."); P0 = ~0xA2; while(1); } ISPAL++; if(ISPAL == 0) { ISPAH++; } u8Read_Data++; } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Erase_CONFIG(void) { BIT EA_TMP; EA_TMP = EA; EA = 0; Enable_ISP_Mode(); P0 = ~0x05; ISPCN = ERASE_ALL_CONFIG; ISPAL = 0x00; ISPAH = 0x00; Trigger_ISP(); Disable_ISP_Mode(); EA = EA_TMP; } //----------------------------------------------------------------------------------------------------------- void Program_CONFIG(UINT8 u8CONFIG_NUMBER,UINT8 u8Value) { BIT EA_TMP; EA_TMP = EA; EA = 0; Enable_ISP_Mode(); P0 = ~0x06; ISPAL = u8CONFIG_NUMBER; ISPAH = 0x00; ISPFD = u8Value; ISPCN = BYTE_PROGRAM_CONFIG; Trigger_ISP(); Disable_ISP_Mode(); EA = EA_TMP; } //----------------------------------------------------------------------------------------------------------- UINT8 Read_CONFIG(UINT8 u8CONFIG_NUMBER) { UINT8 u8Read_Data; Enable_ISP_Mode(); P0 = ~0x07; ISPAL = u8CONFIG_NUMBER; ISPAH = 0x00; u8Read_Data = 0x00; ISPCN = FLASH_READ_CONFIG; Trigger_ISP(); u8Read_Data = ISPFD; Disable_ISP_Mode(); return u8Read_Data; } //----------------------------------------------------------------------------------------------------------- void main (void) { Clear_BOF(); InitialUART0_Timer1(9600); // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz printf ("\n N79E715 ISP LDROM Program Data Flash Sample Code."); Erase_DATA(); Erase_DATA_Verify(); Program_DATA(); Program_DATA_Verify(); printf ("\nN79E715 ISP LDROM Program Data Flash OK!\n"); P14 = 0; P21 = 0; while(1); } //-----------------------------------------------------------------------------------------------------------
/*---------------------------------------------------------------------------------------------------------*/ /* */ /* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved. */ /* */ /*---------------------------------------------------------------------------------------------------------*/ //*********************************************************************************************************** // Nuvoton Technology Corp. // E-mail: MicroC-8bit@nuvoton.com //*********************************************************************************************************** // Application: APROM program Data Flash Function // ISP_AP.bin need to program to APROM // Config0 bit0(DFEN) =0 (enable DFEN) // Config1(CHBDA)=0x30 // Output : Test OK => P0 = 0 // Erase Data Verify err => P0 = ~0xA1 // Program Data Verify err => P0 = ~0xA2 //*********************************************************************************************************** //------------------------- <<< Use Configuration Wizard in Context Menu >>> -------------------------------- // <h> UART pin Select // <o0.6> UART pin // <0=> Select P1.0, P1.1 as UART pin(default) // <1=> Select P2.6, P2.7 as UART pin(28 pin only) // </h> //-------------------------------- <<< end of configuration section >>> ------------------------------------- #define Uart_Port_Sel 0x00 #include "N79E715.h" #include "Typedef.h" #include "Define.h" #include "Common.h" #include "Delay.h" #include "Version.h" #include <intrins.h> #include <stdio.h> #include <string.h> #define ERASE_ALL_DATA 0x22 #define FLASH_READ_DATA 0x00 #define BYTE_PROGRAM_DATA 0x21 #define ERASE_ALL_CONFIG 0xE2 #define FLASH_READ_CONFIG 0xC0 #define BYTE_PROGRAM_CONFIG 0xE1 bit EA_Save_bit; //----------------------------------------------------------------------------------------------------------- void Clear_BOF(void) { EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; PMCR &= CLR_BIT3; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Enable_ISP_Mode(void) { /* Enable ISP */ EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; CHPCON |= 0x01; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Disable_ISP_Mode(void) { /* Disable ISP */ EA_Save_bit = EA; EA = 0; TA = 0xAA; TA = 0x55; CHPCON &= 0xFE; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Trigger_ISP(void) { EA_Save_bit = EA; EA = 0; EA = 0; TA = 0xAA; TA = 0x55; ISPTRG |= 0x01; EA = EA_Save_bit; } //----------------------------------------------------------------------------------------------------------- void Erase_DATA(void) { UINT16 u16Count; Enable_ISP_Mode(); P0 = ~0x01; ISPCN = ERASE_ALL_DATA; for(u16Count=96;u16Count<128;u16Count++) { ISPAL = LOBYTE(u16Count*128); // 96*128=12288=0x3000 ISPAH = HIBYTE(u16Count*128); // 96*128=12288=0x3000 Trigger_ISP(); } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Erase_DATA_Verify(void) { UINT16 u16Count; Enable_ISP_Mode(); P0 = ~0x02; ISPAL = 0x00; ISPAH = 0x30; ISPCN = FLASH_READ_DATA; for(u16Count=12288;u16Count<16384;u16Count++) { ISPFD = 0; Trigger_ISP(); if(ISPFD != 0xFF) { printf ("\nEV err."); P0 = ~0xA1; while(1); } ISPAL++; if(ISPAL == 0) { ISPAH++; } } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Program_DATA(void) { UINT16 u16Count; Enable_ISP_Mode(); P0 = ~0x03; ISPAL = 0x00; ISPAH = 0x30; ISPFD = 0xFF; ISPCN = BYTE_PROGRAM_DATA; for(u16Count=12288;u16Count<16384;u16Count++) { ISPFD++; Trigger_ISP(); ISPAL++; if(ISPAL == 0) { ISPAH++; } } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void Program_DATA_Verify(void) { UINT16 u16Count; UINT8 u8Read_Data; Enable_ISP_Mode(); P0 = ~0x04; ISPAL = 0x00; ISPAH = 0x30; u8Read_Data = 0x00; ISPCN = FLASH_READ_DATA; for(u16Count=12288;u16Count<16384;u16Count++) { Trigger_ISP(); if(ISPFD != u8Read_Data) { printf ("\nPV err."); P0 = ~0xA2; while(1); } ISPAL++; if(ISPAL == 0) { ISPAH++; } u8Read_Data++; } Disable_ISP_Mode(); } //----------------------------------------------------------------------------------------------------------- void main (void) { Clear_BOF(); AUXR1 |= Uart_Port_Sel; // Select P10/P11 as UART pin(default) InitialUART0_Timer1(9600); // 9600 Baud Rate @ 11.0592MHz Show_Version_Number_To_PC(); printf ("\n N79E84x ISP APROM Program Data Flash Sample Code."); Erase_DATA(); Erase_DATA_Verify(); Program_DATA(); Program_DATA_Verify(); printf ("\n N79E715 ISP APROM Program Data Flash OK!\n"); P14 = 0; P21 = 0; while(1); } //-----------------------------------------------------------------------------------------------------------
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
