IAR裸奔Beaglebone black, DDR3初始化成功,但进入DEBUG时报Cou...
4164|52
 楼主| ilostid 发表于 2016-12-30 00:33 | 显示全部楼层 |阅读模式
裸奔Beaglebone black, 貌似DDR3初始化成功,但进入DEBUG时报Could not start CPU(如附件图片所示),郁闷,大家给点建议吧,附修改好的AM335X_BBB_DDR3.mac,不过不清楚修改对没。有兴趣的可以试试,看是否会碰到我一样的错误。
JLINK V9
IAR 7.0
点击download and debug 后,初始化IAR输出后打印信息如下:
Fri Dec 30, 2016 00:19:42: Loaded macro file: C:\ti\AM335X_StarterWare_02_00_01_01\tools\ewarm\AM335x_BBB_DDR3.mac
Fri Dec 30, 2016 00:19:43: JLINK command: ProjectFile = C:\ti\AM335X_StarterWare_02_00_01_01\build\armv7a\ewarm\am335x\beaglebone\uart\settings\uartEcho_Debug.jlink, return = 0
Fri Dec 30, 2016 00:19:43: Device "AM3358" selected (0 KB flash, 0 KB RAM).
Fri Dec 30, 2016 00:19:43: DLL version: V4.80g, compiled Feb 13 2014 20:50:02
Fri Dec 30, 2016 00:19:43: Firmware: J-Link V9 compiled Apr 22 2016 11:47:06
Fri Dec 30, 2016 00:19:43: JTAG speed is initially set to: 32 kHz
Fri Dec 30, 2016 00:19:43: Initial reset was performed
Fri Dec 30, 2016 00:19:43: TotalIRLen = 6, IRPrint = 0x01
Fri Dec 30, 2016 00:19:43: TotalIRLen = 10, IRPrint = 0x0011
Fri Dec 30, 2016 00:19:43: ARM AP[0]: 0x04770001, AHB-AP
Fri Dec 30, 2016 00:19:43: ARM AP[1]: 0x04770002, APB-AP
Fri Dec 30, 2016 00:19:43: ARM AP[2]: 0x04760000, JTAG-AP
Fri Dec 30, 2016 00:19:43: Found Cortex-A8 r3p2
Fri Dec 30, 2016 00:19:43: 6 code breakpoints, 2 data breakpoints
Fri Dec 30, 2016 00:19:43: Data endian: little
Fri Dec 30, 2016 00:19:43: Main ID register: 0x413FC082
Fri Dec 30, 2016 00:19:43: L1 (I-cache): 32 KB, 128 sets, LineSize 64 bytes, 4-way
Fri Dec 30, 2016 00:19:43: L1 (D-cache): 32 KB, 128 sets, LineSize 64 bytes, 4-way
Fri Dec 30, 2016 00:19:43: L2 (unified cache): 0 KB, 1 sets, LineSize 256 bytes, 1-way
Fri Dec 30, 2016 00:19:43: System control register:
Fri Dec 30, 2016 00:19:43:   Instruction endian: little
Fri Dec 30, 2016 00:19:43:   Level-1 instruction cache disabled
Fri Dec 30, 2016 00:19:43:   Level-1 data cache disabled
Fri Dec 30, 2016 00:19:43:   MMU disabled
Fri Dec 30, 2016 00:19:43:   Branch prediction enabled
Fri Dec 30, 2016 00:19:43: Found 2 JTAG devices, Total IRLen = 10:
Fri Dec 30, 2016 00:19:43:  #0 Id: 0x3BA00477, IRLen:  4, IRPrint: 0x1 CoreSight JTAG-DP
Fri Dec 30, 2016 00:19:43:  #1 Id: 0x2B94402F, IRLen:  6, IRPrint: 0x1 TI ICEPick
Fri Dec 30, 2016 00:19:44:  AM335x EVM-SK Initialization is in progress ..........
Fri Dec 30, 2016 00:19:44: ****  Subarctic ALL ADPLL Config for OPP == OPP100 is In Progress .........
Fri Dec 30, 2016 00:19:44: Input Clock Read from SYSBOOT[15:14]:  24MHz
Fri Dec 30, 2016 00:19:44: ****  Going to Bypass...
Fri Dec 30, 2016 00:19:44: ****  Bypassed, changing values...
Fri Dec 30, 2016 00:19:44: ****  Locking ARM PLL
Fri Dec 30, 2016 00:19:44: ****  Core Bypassed
Fri Dec 30, 2016 00:19:44: ****  Now locking Core...
Fri Dec 30, 2016 00:19:44: ****  Core locked
Fri Dec 30, 2016 00:19:44: ****  DDR DPLL Bypassed
Fri Dec 30, 2016 00:19:45: ****  DDR DPLL Locked
Fri Dec 30, 2016 00:19:45: ****  PER DPLL Bypassed
Fri Dec 30, 2016 00:19:45: ****  PER DPLL Locked
Fri Dec 30, 2016 00:19:45: ****  DISP PLL Config is in progress ..........
Fri Dec 30, 2016 00:19:45: ****  DISP PLL Config is DONE ..........
Fri Dec 30, 2016 00:19:45: ****  Subarctic ALL ADPLL Config for OPP == OPP100 is Done .........
Fri Dec 30, 2016 00:19:45: ****  AM335x OPP120 DDR3 EMIF and PHY configuration is in progress.........
Fri Dec 30, 2016 00:19:45: EMIF PRCM is in progress .......
Fri Dec 30, 2016 00:19:45: EMIF PRCM Done
Fri Dec 30, 2016 00:19:45: DDR PHY Configuration In progress
Fri Dec 30, 2016 00:19:45: GPIO module clock configuration is done .......
Fri Dec 30, 2016 00:19:46: Waiting for VTP Ready .......
Fri Dec 30, 2016 00:19:46: VTP Enable Done
Fri Dec 30, 2016 00:19:46: DDR PHY CMD Register configuration is in progress .......
Fri Dec 30, 2016 00:19:46: DDR PHY Data Register configuration is in progress .......
Fri Dec 30, 2016 00:19:47: EMIF Timing register configuration is in progress .......
Fri Dec 30, 2016 00:19:47: EMIF Timing register configuration is done .......
Fri Dec 30, 2016 00:19:47: PHY is READY!!
Fri Dec 30, 2016 00:19:47: DDR PHY Configuration done
Fri Dec 30, 2016 00:19:47: ****  AM335x OPP120 DDR3 EMIF and PHY configuration is done.........
Fri Dec 30, 2016 00:19:47:  AM335x EVM-SK Initialization is done ..........
Fri Dec 30, 2016 00:19:48: 33592 bytes downloaded (105.14 Kbytes/sec)
Fri Dec 30, 2016 00:19:48: Loaded debugee: C:\ti\AM335X_StarterWare_02_00_01_01\binary\armv7a\ewarm\am335x\beaglebone\uart\Debug\uartEcho.out
Fri Dec 30, 2016 00:19:48: Target reset
dirtwillfly 发表于 2016-12-30 21:34 | 显示全部楼层
楼主加油,没玩过这个裸奔
pixhw 发表于 2016-12-30 21:50 | 显示全部楼层
没有用过这个IAR开发这个。
 楼主| ilostid 发表于 2016-12-30 21:51 | 显示全部楼层
楼主加油,没玩过这个裸奔
想一下,若这个频率和资源,裸奔多得劲啊
可惜还没整好,郁闷呢。
pixhw 发表于 2016-12-30 21:52 | 显示全部楼层
楼主有其他的工程文件吗?
 楼主| ilostid 发表于 2016-12-30 21:54 | 显示全部楼层
楼主有其他的工程文件吗?
其他就是TI的STARTWARE可以在TI官网下载到的
 楼主| ilostid 发表于 2016-12-30 22:01 | 显示全部楼层
sanxingnote7 发表于 2016-12-31 17:04 | 显示全部楼层
你启动方式用的什么?
sanxingnote7 发表于 2016-12-31 17:05 | 显示全部楼层
DDR3使用裸奔的时候怎么使用的?
 楼主| ilostid 发表于 2016-12-31 19:53 | 显示全部楼层
DDR3使用裸奔的时候怎么使用的?
就是附件文件,AM335X_BBB_DDR3.rar
那个有相关的初始化
我的理解是程序是跑在ram的,掉电上电后就没有了。
不知理解对不对。
你启动方式用的什么?
那个有相关的初始化
我的理解是程序是跑在ram的,掉电上电后就没有了。不知理解对不对。
kkzz 发表于 2017-1-2 21:13 | 显示全部楼层
你的启动不成功吗?
kkzz 发表于 2017-1-2 21:46 | 显示全部楼层
启动模式是从哪里设置的?
xiaoyaodz 发表于 2017-1-2 22:49 | 显示全部楼层
DDR3没有裸机开发过。
xiaoyaodz 发表于 2017-1-2 22:51 | 显示全部楼层
楼主还是使用CCS去试试看。
wangdezhi 发表于 2017-1-3 21:52 | 显示全部楼层
想一起裸奔,请参考:https://bbs.21ic.com/icview-757324-1-1.html
这个直接运行程序怎么样
wangdezhi 发表于 2017-1-3 21:53 | 显示全部楼层
楼主还是使用CCS去试试看。
CCS开发怎么调用库
51xlf 发表于 2017-1-4 17:03 | 显示全部楼层
DDR3有保护吗?
51xlf 发表于 2017-1-4 17:10 | 显示全部楼层
DEBUG的时候能够写入吗?
youtome 发表于 2017-1-4 17:21 | 显示全部楼层
没有用过IAR开发beaglebone
