[DemoCode下载]
N79E715的PWM操作方法
1465|4
huangcunxiake|  楼主 | 2017-1-10 22:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
/* Copyright(c) 2015 Nuvoton Technology Corp. All rights reserved.                                         */
//  Nuvoton Technology Corp.
//  E-mail: MicroC-8bit@nuvoton.com
//  Application: PWM Function
//  Set PWM output channel, PWM frequency and PWM duty before PWM running
//  PWM will be braked to a stop when P0.2 is low level
//  Output : PWM channel 0 => P0.1 (default)
//           PWM channel 1 => P1.6
//           PWM channel 2 => P1.7
//           PWM channel 3 => P0.0
//========================================= How to set PWM register =========================================
//  1.set load = 1; PWMRUN=1; ==> PWMCON0=0xC0;
//  2.Frequency == Fpwm/(PWMP+1)
//  3.Duty = PWMn/PWMP+1
//------------------------- <<< Use Configuration Wizard in Context Menu >>> --------------------------------
//      <o0.0..9> PWM Period<0-1023>
//      <o1.0..9> PWM0(P01) Duty<0-1023>
//      <o2.0..9> PWM1(P16) Duty<0-1023>
//      <o3.0..9> PWM2(P17) Duty<0-1023>
//      <o4.0..9> PWM3(P00) Duty<0-1023>
//     <o5.6> UART pin Select
//          <0=> Select P1.0, P1.1 as UART pin(default)
//          <1=> Select P2.6, P2.7 as UART pin(28 pin only)
//-------------------------------- <<< end of configuration section >>> -------------------------------------
#define PWMP            0x3FF
#define PWM0_Duty       0x200
#define PWM1_Duty       0x100
#define PWM2_Duty       0x080
#define PWM3_Duty       0x040
#define Uart_Port_Sel   0x00
typedef enum
    E_CHANNEL0,
    E_CHANNEL1,
    E_CHANNEL2,
    E_CHANNEL3,
} E_PWMCNL_SEL;
#include <stdio.h>
#include "N79E715.h"
#include "Typedef.h"
#include "Define.h"
#include "Common.h"
#include "Version.h"
#include <intrins.h>
UINT16 PWM_shadow;
void Init_PWM(void)
    AUXR1 |= Uart_Port_Sel;             // Select P10/P11 as UART pin(default)
    InitialUART0_Timer1(9600);          // 9600 Baud Rate [url=home.php?mod=space&uid=72445]@[/url] 11.0592MHz
    printf ("\n*===================================================================");
    printf ("\n*  Name: N79E715 Series PWM Sample Code.");
    printf ("\nPWM Demo Start.\n");
    PWM_shadow = PWMP;
    PWMPH = HIBYTE(PWM_shadow);         // PWM Period
    PWMPL = LOBYTE(PWM_shadow);
    PWMCON0 |= 0xD0;                    // Enable PWM and select auto reload mode
void PWM_Pin_Recover_to_High(void)
    PWMCON0 = 0x00;
    PWMCON1 = 0x00;
    PWMCON2 = 0x00;
    PWMPH   = 0x00;
    PWMPL   = 0x01;
    PWM0H   = 0x00;
    PWM0L   = 0x00;
    PWM1H   = 0x00;
    PWM1L   = 0x00;
    PWM2H   = 0x00;
    PWM2L   = 0x00;
    PWM3H   = 0x00;
    PWM3L   = 0x00;
    PWMCON0 |= 0xD0;// PWM always non-active(high).
    _nop_ ();       // NOP
    PWMCON0 &= 0x0F;// PWM Stop
    PWMPL   = 0x00; // Recover to reset value
void PWM_Channel(E_PWMCNL_SEL Channel)
    switch(Channel)
        case E_CHANNEL0:
            PWM_shadow=PWM0_Duty;
            PWM0H = HIBYTE(PWM_shadow);// PWM0 Duty (P0.1)
            PWM0L = LOBYTE(PWM_shadow);
            break;
        case E_CHANNEL1:
            PWM_shadow=PWM1_Duty;
            PWM1H = HIBYTE(PWM_shadow);// PWM1 Duty (P1.6)
            PWM1L = LOBYTE(PWM_shadow);
            break;
        case E_CHANNEL2:
            PWM_shadow=PWM2_Duty;
            PWM2H = HIBYTE(PWM_shadow);// PWM2 Duty (P1.7)
            PWM2L = LOBYTE(PWM_shadow);
            break;
        case E_CHANNEL3:
            PWM_shadow=PWM3_Duty;
            PWM3H = HIBYTE(PWM_shadow);// PWM3 Duty (P0.0)
            PWM3L = LOBYTE(PWM_shadow);
            break;
void Enabled_Brake_Function(void)
    PWMCON1 = 0x30;                    // PWM is running. PWM will be stopped when P0.2 is low level.
void main(void)
    PWM_Channel(E_CHANNEL0);           // Select PWM channel.
    PWM_Channel(E_CHANNEL1);           // Select PWM channel.
    PWM_Channel(E_CHANNEL2);           // Select PWM channel.
    PWM_Channel(E_CHANNEL3);           // Select PWM channel.
    Init_PWM();                        // Enable PWM function and set PWM period.
    Enabled_Brake_Function();          // Enable Brake function.
    while(1);
huangcunxiake|  楼主 | 2017-1-10 22:56 | 只看该作者
通过这例程可以充分体验到这个单片机PWM的强大的功能。
kk5004| | 2017-1-11 09:26 | 只看该作者
很好啊
gejigeji521| | 2017-1-11 19:23 | 只看该作者
switch case用的果然出神入化。
643757107| | 2017-1-11 23:56 | 只看该作者
一共4个通道。
