[汽车MCU – KEA]
KEA128进不了AD中断问题
1780|1
xpepe|  楼主 | 2017-1-11 15:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大虾帮我看看,我为什么进不了AD采样完成中断,是哪个寄存器没写对还是中断函数没写对,急急急!!!谢谢。
void init_ADC(void)  {
  SIM_SCGC |= SIM_SCGC_ADC_MASK;                /* Enable bus clock to ADC module */
  ADC_SC1 = 0x4A;
        /* AIEN = 1: Interrupts enabled  */
        /* ADCO = 1: Continuous conversions enabled  */
  ADC_APCTL1 = 0x00000400;              /* Enable ADC channels 10 (PTC2) */
  ADC_SC3 = 0x00000005;                 /* Select ADCACLK, no divide, 10 bit conversion */
                                            /* ADLPC = 0 (default): hi speed config */
                                            /* ADIV = 0 (default): clock rate = input clock/1 */
                                            /* ADLSMP = 0 (default): short sample time */
                                            /* MODE = 1: 10 bit conversion */
                                            /* ADICLK= 1:Bus clock/2 source */
  ADC_SC2 =0x00000000;                  /* SW trigger, default ref pins, no compare */
        /* ADTRG = 0 (default): SW Trigger */
                                            /* ACFE = 0 (default):  compare function disabled */
        /* REFSEL = 0 (default): default ref volt pin pair */
中断向量表:
/* The Interrupt Vector Table */
void (* const InterruptVector[])() __attribute__ ((section(".vectortable"))) = {
    /* Processor exceptions */
    (void(*)(void)) &_estack,
    __thumb_startup,
    NMI_Handler,
    HardFault_Handler,
   ADC0_IRQHandler,                /* ADC conversion complete interrupt */
void ADC0_IRQHandler() __attribute__ ((weak, alias("Default_Handler")));
main(void)
         init_clks_FEE_40MHz();
         init_ADC();
         Enable_Interrupt(INT_ADC0);                  /* Enable ADC0 interrupt */
        for(;;) {
         a ++;
void ADC0_IRQHandler(void){     //中断函数
        counter++;
xpepe|  楼主 | 2017-1-11 15:34 | 只看该作者
没人回复
