[Actel FPGA] 请斑竹帮忙看一下,仿真时提示的错误什么意思?
2900|1
 楼主| bit6019 发表于 2010-4-10 18:13 | 显示全部楼层 |阅读模式
做的是分频实验,目的是由 48MHz 的晶振得到 1Hz 的方波信号。板子是AFS600的 Fusion Startkit 。用 ModelSim 仿真时,提示以下错误:  (激励文件是由WaveFormer 编写的)   工程名是 “ Square_Wave3
# Loading postlayout.testbench
# Loading postlayout.stimulus
# Loading postlayout.tb_clock_minmax
# SDF 6.5d Compiler 2009.11 Nov 19 2009
# ACTEL version supports only a single HDL
# ** Fatal: (vsim-3039) D:/Actelprj/Square_Wave3/stimulus/Square_Wave3_tbench.v(249): Instantiation of 'Square_Wave3' failed.
#    Time: 0 ps  Iteration: 0  Instance: /testbench File: D:/Actelprj/Square_Wave3/stimulus/Square_Wave3_tbench.v
# FATAL ERROR while loading design
# Error loading design
# Error: Error loading design
#        Pausing macro execution
# MACRO ./run.do PAUSED at line 16
# Error attempted to pushdown all children on .main_pane.cs.24 mode is tabbed children are paneframes 1
   VSIM(paused)> LedOut:OUT Std_Logic
        请问是哪里出错啦?谢谢!
LPC300 发表于 2010-4-10 18:57 | 显示全部楼层
好像是实例化失败了
