[嵌入式linux]
为什么挂载不上根文件系统
1451|2
zpf0506|  楼主 | 2017-1-22 17:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
TE, ST, AN, se, AC
SMDK2440 # set bootargs root=1f01 console=ttySAC0,115200 init=/linuxrc devfs=mount rootfstype=jffs2
SMDK2440 # save
Saving Environment to Flash...
Un-Protected 1 sectors
Erasing Flash...Erasing sector 18 ... ok.
Erased 1 sectors
Writing to Flash... done
Protected 1 sectors
MDK2440 # reset
U-Boot 1.3.4 (Jan 22 2017 - 01:15:13)
DRAM:  64 MB
Flash:  1 MB
NAND:  board_nand_init()
end of nand_init
256 MiB
In:    serial
Out:   serial
Err:   serial
ERROR: resetting DM9000 -> not responding
dm9000 i/o: 0x20000000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 08:00:3e:26:0a:5b
operating at unknown: 0 mode
Hit any key to stop autoboot:  0
Usage:
nand    - NAND sub-system
## Booting kernel from Legacy Image at 32000000 ...
   Image Name:   Linux-2.6.22.6
   Created:      2017-01-21  14:20:03 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1564404 Bytes =  1.5 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux..................................................................................................... done, booting the kernel.
Linux version 2.6.22.6 (root@localhost.localdomain) (gcc version 4.4.3 (ctng-1.6.1) ) #6 Sat Jan 21 22:19:52 CST 2017
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=00007177
Machine: SMDK2440
Warning: bad configuration page, trying to continue
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C24XX Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists.  Total pages: 4064
Kernel command line: root=/dev/hda1 ro init=/bin/bash console=ttySAC0
irq: clearing subpending status 00000002
PID hash table entries: 64 (order: 6, 256 bytes)
timer tcon=00500000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8
Console: colour dummy device 80x30
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory: 16MB = 16MB total
Memory: 12880KB available (2856K code, 314K data, 128K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C2410 Power Management, (c) 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C2440: Clock Support, DVS off
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c1800000, irq 33
DMA channel 1 at c1800040, irq 34
DMA channel 2 at c1800080, irq 35
DMA channel 3 at c18000c0, irq 36
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 512 (order: 0, 4096 bytes)
TCP bind hash table entries: 512 (order: -1, 2048 bytes)
TCP: Hash tables configured (established 512 bind 512)
TCP reno registered
NetWinder Floating Point Emulator V0.97 (double precision)
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
yaffs Jan 21 2017 22:16:44 Installing.
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
s3c2410-lcd s3c2410-lcd: invalid bpp 16
Console: switching to colour frame buffer device 30x40
fb0: s3c2410fb frame buffer device
lp: driver loaded but no devices found
ppdev: user-space parallel port driver
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
loop: module loaded
dm9000 Ethernet Driver
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
BAST NOR-Flash Driver, (c) 2004 Simtec Electronics
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=3, 30ns Twrph0=7 70ns, Twrph1=3 30ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 24 at 0x00300000
Creating 3 MTD partitions on "NAND 256MiB 3,3V 8-bit":
0x00000000-0x00200000 : "kernel"
0x00200000-0x00a00000 : "jffs2"
0x00a00000-0x10000000 : "yaffs"
usbmon: debugfs is not available
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 390 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
TCP cubic registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "hda1" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
1f00       2048 mtdblock0 (driver?)
1f01       8192 mtdblock1 (driver?)
1f02     251904 mtdblock2 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
renxiaolin| | 2017-2-4 14:59 | 只看该作者
那你没看到“内核恐慌”
QQ1215483516| | 2017-2-28 15:26 | 只看该作者
我有标准LINUX DM9000驱动,需要可以联系1
