[DemoCode下载] M058S串口收发
1046|7
 楼主| 643757107 发表于 2017-1-28 12:38 | 显示全部楼层 |阅读模式
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 4 $
  5. * $Date: 15/02/06 10:23a $
  6. * [url=home.php?mod=space&uid=247401]@brief[/url]    Transmit and receive data from PC terminal through RS232 interface.
  7. * @note
  8. * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
  9. *
  10. ******************************************************************************/
  11. #include <stdio.h>
  12. #include "M058S.h"
  13. #define PLL_CLOCK           50000000
  14. #define RXBUFSIZE 1024
  15. /*---------------------------------------------------------------------------------------------------------*/
  16. /* Global variables        */
  17. /*---------------------------------------------------------------------------------------------------------*/
  18. uint8_t g_u8RecData[RXBUFSIZE]  = {0};
  19. volatile uint32_t g_u32comRbytes = 0;
  20. volatile uint32_t g_u32comRhead  = 0;
  21. volatile uint32_t g_u32comRtail  = 0;
  22. volatile int32_t g_bWait         = TRUE;
  23. /*---------------------------------------------------------------------------------------------------------*/
  24. /* Define functions prototype        */
  25. /*---------------------------------------------------------------------------------------------------------*/
  26. int32_t main(void);
  27. void UART_TEST_HANDLE(void);
  28. void UART_FunctionTest(void);
  29. void SYS_Init(void)
  30. {
  31.     /*---------------------------------------------------------------------------------------------------------*/
  32.     /* Init System Clock        */
  33.     /*---------------------------------------------------------------------------------------------------------*/
  34.     /* Enable Internal RC 22.1184MHz clock */
  35.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  36.     /* Waiting for Internal RC clock ready */
  37.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  38.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  39.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  40.     /* Enable external XTAL 12MHz clock */
  41.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  42.     /* Waiting for external XTAL clock ready */
  43.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  44.     /* Set core clock as PLL_CLOCK from PLL */
  45.     CLK_SetCoreClock(PLL_CLOCK);
  46.     /* Enable UART module clock */
  47.     CLK_EnableModuleClock(UART0_MODULE);
  48.     /* Select UART module clock source */
  49.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  50.     /*---------------------------------------------------------------------------------------------------------*/
  51.     /* Init I/O Multi-function        */
  52.     /*---------------------------------------------------------------------------------------------------------*/
  53.     /* Set P3 multi-function pins for UART0 RXD and TXD */
  54.     SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
  55.     SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD);
  56. }
  57. void UART0_Init()
  58. {
  59.     /*---------------------------------------------------------------------------------------------------------*/
  60.     /* Init UART        */
  61.     /*---------------------------------------------------------------------------------------------------------*/
  62.     /* Reset UART0 */
  63.     SYS_ResetModule(UART0_RST);
  64.     /* Configure UART0 and set UART0 Baudrate */
  65.     UART_Open(UART0, 115200);
  66. }
  67. /*---------------------------------------------------------------------------------------------------------*/
  68. /* UART Test Sample        */
  69. /* Test Item        */
  70. /* It sends the received data to HyperTerminal.                                                            */
  71. /*---------------------------------------------------------------------------------------------------------*/
  72. /*---------------------------------------------------------------------------------------------------------*/
  73. /* MAIN function        */
  74. /*---------------------------------------------------------------------------------------------------------*/
  75. int main(void)
  76. {
  77.     /* Unlock protected registers */
  78.     SYS_UnlockReg();
  79.     /* Init System, peripheral clock and multi-function I/O */
  80.     SYS_Init();
  81.     /* Lock protected registers */
  82.     SYS_LockReg();
  83.     /* Init UART0 for printf and testing */
  84.     UART0_Init();
  85.     /*---------------------------------------------------------------------------------------------------------*/
  86.     /* SAMPLE CODE        */
  87.     /*---------------------------------------------------------------------------------------------------------*/
  88.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  89.     printf("\n\nUART Sample Program\n");
  90.     /* UART sample function */
  91.     UART_FunctionTest();
  92.     while(1);
  93. }
  94. /*---------------------------------------------------------------------------------------------------------*/
  95. /* ISR to handle UART Channel 0 interrupt event                                                            */
  96. /*---------------------------------------------------------------------------------------------------------*/
  97. void UART0_IRQHandler(void)
  98. {
  99.     UART_TEST_HANDLE();
  100. }
  101. /*---------------------------------------------------------------------------------------------------------*/
  102. /* UART Callback function        */
  103. /*---------------------------------------------------------------------------------------------------------*/
  104. void UART_TEST_HANDLE()
  105. {
  106.     uint8_t u8InChar = 0xFF;
  107.     uint32_t u32IntSts = UART0->ISR;
  108.     if(u32IntSts & UART_ISR_RDA_INT_Msk)
  109.     {
  110.         printf("\nInput:");
  111.         /* Get all the input characters */
  112.         while(UART_IS_RX_READY(UART0))
  113.         {
  114.             /* Get the character from UART Buffer */
  115.             u8InChar = UART_READ(UART0);
  116.             printf("%c ", u8InChar);
  117.             if(u8InChar == '0')
  118.             {
  119.                 g_bWait = FALSE;
  120.             }
  121.             /* Check if buffer full */
  122.             if(g_u32comRbytes < RXBUFSIZE)
  123.             {
  124.                 /* Enqueue the character */
  125.                 g_u8RecData[g_u32comRtail] = u8InChar;
  126.                 g_u32comRtail = (g_u32comRtail == (RXBUFSIZE - 1)) ? 0 : (g_u32comRtail + 1);
  127.                 g_u32comRbytes++;
  128.             }
  129.         }
  130.         printf("\nTransmission Test:");
  131.     }
  132.     if(u32IntSts & UART_ISR_THRE_INT_Msk)
  133.     {
  134.         uint16_t tmp;
  135.         tmp = g_u32comRtail;
  136.         if(g_u32comRhead != tmp)
  137.         {
  138.             u8InChar = g_u8RecData[g_u32comRhead];
  139.             UART_WRITE(UART0, u8InChar);
  140.             g_u32comRhead = (g_u32comRhead == (RXBUFSIZE - 1)) ? 0 : (g_u32comRhead + 1);
  141.             g_u32comRbytes--;
  142.         }
  143.     }
  144. }
  145. /*---------------------------------------------------------------------------------------------------------*/
  146. /*  UART Function Test        */
  147. /*---------------------------------------------------------------------------------------------------------*/
  148. void UART_FunctionTest()
  149. {
  150.     printf("+-----------------------------------------------------------+\n");
  151.     printf("|  UART Function Test                                       |\n");
  152.     printf("+-----------------------------------------------------------+\n");
  153.     printf("|  Description :                                            |\n");
  154.     printf("|    The sample code will print input char on terminal      |\n");
  155.     printf("|    Please enter any to start     (Press '0' to exit)      |\n");
  156.     printf("+-----------------------------------------------------------+\n");
  157.     /*
  158.         Using a RS232 cable to connect UART0 and PC.
  159.         UART0 is set to debug port. UART0 is enable RDA and RLS interrupt.
  160.         When inputing char to terminal screen, RDA interrupt will happen and
  161.         UART0 will print the received char on screen.
  162.     */
  163.     /* Enable Interrupt */
  164.     UART_EnableInt(UART0, (UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk));
  165.     while(g_bWait);
  166.     /* Disable Interrupt */
  167.     UART_DisableInt(UART0, (UART_IER_RDA_IEN_Msk | UART_IER_THRE_IEN_Msk | UART_IER_RTO_IEN_Msk));
  168.     g_bWait = TRUE;
  169.     printf("\nUART Sample Demo End.\n");
  170. }
 楼主| 643757107 发表于 2017-1-28 12:42 | 显示全部楼层
学习例程关键学习每个用户需要编写的函数的编写方法,以及怎么跟手册搭配学习
稳稳の幸福 发表于 2017-1-28 12:57 | 显示全部楼层
发现启动外部时钟的函数是一样的。
wahahaheihei 发表于 2017-1-28 13:27 | 显示全部楼层
这段话要求使用一个终端程序来跟串口通信,有时候串口助手没有终端好用,终端还可发送各种指令。
zhuomuniao110 发表于 2017-1-29 13:22 | 显示全部楼层
串口还要配置时钟呢。
捉虫天师 发表于 2017-1-29 17:09 | 显示全部楼层
串口最基本的一种模式,主要用于现场总线的应用。
稳稳の幸福 发表于 2017-1-30 08:43 | 显示全部楼层
通过串口测试函数对收发进行测试。
玛尼玛尼哄 发表于 2017-1-31 17:56 | 显示全部楼层
在我看来仅持于io的技能
