[DemoCode下载]
M058S的模数转换的单曲循环模数
839|6
捉虫天师|  楼主 | 2017-1-31 10:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]    main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.0
* $Revision: 2 $
* $Date: 15/02/06 10:22a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    Perform A/D Conversion with ADC single cycle scan mode.
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M058S.h"
#define PLL_CLOCK       50000000
/* Define Function Prototypes        */
void SYS_Init(void);
void UART0_Init(void);
void AdcSingleCycleScanModeTest(void);
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Enable ADC module clock */
    CLK_EnableModuleClock(ADC_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
    /* ADC clock source is 22.1184 MHz, set divider to 7, ADC clock is 22.1184/7 MHz */
    CLK_SetModuleClock(ADC_MODULE, CLK_CLKSEL1_ADC_S_HIRC, CLK_CLKDIV_ADC(7));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= SYS_MFP_P30_RXD | SYS_MFP_P31_TXD;
    /* Disable the P1.0 - P1.3 digital input path to avoid the leakage current */
    GPIO_DISABLE_DIGITAL_PATH(P1, 0xF);
    /* Configure the P1.0 - P1.3 ADC analog input pins */
    SYS->P1_MFP &= ~(SYS_MFP_P10_Msk | SYS_MFP_P11_Msk | SYS_MFP_P12_Msk | SYS_MFP_P13_Msk);
    SYS->P1_MFP |= SYS_MFP_P10_AIN0 | SYS_MFP_P11_AIN1 | SYS_MFP_P12_AIN2 | SYS_MFP_P13_AIN3 ;
/* Init UART        */
void UART0_Init()
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* Function: AdcSingleCycleScanModeTest        */
/* Parameters:        */
/*   None.        */
/* Returns:        */
/*   None.        */
/* Description:        */
/*   ADC single cycle scan mode test.        */
void AdcSingleCycleScanModeTest()
    uint8_t  u8Option;
    uint32_t u32ChannelCount;
    int32_t  i32ConversionData;
    printf("\n");
    printf("+----------------------------------------------------------------------+\n");
    printf("|                 ADC single cycle scan mode sample code               |\n");
    while(1)
        printf("\n\nSelect input mode:\n");
        printf("  [1] Single end input (channel 0, 1, 2 and 3)\n");
        printf("  [2] Differential input (input channel pair 0 and 1)\n");
        printf("  Other keys: exit single cycle scan mode test\n");
        u8Option = getchar();
        if(u8Option == '1')
            /* Set the ADC operation mode as single-cycle, input mode as single-end and
                 enable the analog input channel 0, 1, 2 and 3 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_SINGLE_END, ADC_ADCR_ADMD_SINGLE_CYCLE, 0xF);
            /* Power on ADC module */
            ADC_POWER_ON(ADC);
            /* clear the A/D interrupt flag for safe */
            ADC_CLR_INT_FLAG(ADC, ADC_ADF_INT);
            /* start A/D conversion */
            ADC_START_CONV(ADC);
            /* Wait conversion done */
            while(!ADC_GET_INT_FLAG(ADC, ADC_ADF_INT));
            for(u32ChannelCount = 0; u32ChannelCount < 4; u32ChannelCount++)
                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount);
                printf("Conversion result of channel %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
        else if(u8Option == '2')
            /* Set the ADC operation mode as single-cycle, input mode as differential and
               enable analog input channel 0 and 2 */
            ADC_Open(ADC, ADC_ADCR_DIFFEN_DIFFERENTIAL, ADC_ADCR_ADMD_SINGLE_CYCLE, 0x5);
            ADC_POWER_ON(ADC);
            for(u32ChannelCount = 0; u32ChannelCount < 2; u32ChannelCount++)
                i32ConversionData = ADC_GET_CONVERSION_DATA(ADC, u32ChannelCount * 2);
                printf("Conversion result of differential input pair %d: 0x%X (%d)\n", u32ChannelCount, i32ConversionData, i32ConversionData);
        else
            return ;
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, IP clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    /* SAMPLE CODE        */
    printf("\nSystem clock rate: %d Hz", SystemCoreClock);
    /* Single cycle scan mode test */
    AdcSingleCycleScanModeTest();
    /* Disable ADC module */
    ADC_Close(ADC);
    /* Disable ADC IP clock */
    CLK_DisableModuleClock(ADC_MODULE);
    /* Disable External Interrupt */
    NVIC_DisableIRQ(ADC_IRQn);
    printf("\nExit ADC sample code\n");
    while(1);
捉虫天师|  楼主 | 2017-1-31 10:38 | 只看该作者
这跟歌曲播放很像啊,有单曲循环,顺序播放,多曲循环,哈哈。。
有意思,大家仔细想想是不是,跟那个歌曲的播放的循环模式是一模一样的。
天灵灵地灵灵| | 2017-1-31 19:51 | 只看该作者
就是这个意思
天灵灵地灵灵| | 2017-2-5 15:03 | 只看该作者
如果用HAL库更爽,不知道新唐提供没有
643757107| | 2017-2-6 22:22 | 只看该作者
按照官方的库函数做,确实方便。
mintspring| | 2017-2-7 13:16 | 只看该作者
通过几个简单的函数配置就可以实现你想要的转换方式。
