TI新推出的几款ARM
2290|5
 楼主| wenming 发表于 2010-4-12 13:30 | 显示全部楼层 |阅读模式
ARM, TI, TE, AN, AC
375MHz and 450MHz ARM926EJ-S CPU options (both with MMU)
32KB L1 cache, 128KB L2, and 64KB ROM
NAND, flash, and NOR support
MMC/SD memory interface Programmable Real-time Unit (PRU) for configurable I/O and ARM9 offload
USB 2.0 on-the-go (OTG) with integrated PHY
I2C, SPI, UART interfaces (number of interfaces may vary depending on model)
PWM, eCAP, McASP interfaces (numbers may vary)
64-bit timers (numbers may vary)
Core voltage: 1.2 V (375MHz) or 1.3 V (450MHz) I/O supply (AM17x only): 1.8 V, 3.3 V
Operating temperature: 0 to 90 deg. C (32 to 194 deg. F); -40 to 90 deg. C; -40 to 105 deg.
  最便宜的一款只有6.XX美金,高速的USB接口,100M网络,NAND,等,
关键是QFP176封装,两层PCB就可以了.
zchong 发表于 2010-4-12 22:18 | 显示全部楼层
这个真不错,那款是QFP封装?
不爱说话 发表于 2010-4-13 16:36 | 显示全部楼层
如果有免费样片就更好了
lelee007 发表于 2010-4-13 23:27 | 显示全部楼层
要停电了,mark一下
XZL 发表于 2010-4-14 09:14 | 显示全部楼层
不错!不会像NXP一样,引线乱七八糟吧?速度比NXP快好多
and 发表于 2010-4-14 14:48 | 显示全部楼层
这会抢谁的市场?
个人签名:嵌入式Linux工业控制板,提供ODM与OEM,只做批量,不卖开发板! 欧比特测控   www.OpenEmbed.com
108
