[Actel FPGA] 急!无法打开.sdc文件
2123|1
 楼主| S3C2440 发表于 2010-4-12 20:57 | 显示全部楼层 |阅读模式
布线时复位引脚有错误,就想按照书上写的修改其不连接到CLKBUF的输入端,但无法打开.sdc文件,提示
At line 5 while processing "E:/Actelprj/100K_PWM/synthesis/top_sdc.sdc"
invalid command name "create_clock"
第五行提示:create_clock -period 4.000000 -waveform {0.000000 2.000000} clk_48M,请问这是怎么回事,很急,周工帮忙解答下啊
 楼主| S3C2440 发表于 2010-4-12 21:25 | 显示全部楼层
这是打开时的提示:
# Top Level Design Parameters
# Clocks
createe Path Constraints
# False Paths Between Clocks
# Fals
# Maximum Delay Constraints
# Multicycle Constraints
# Virtual Clocks
# Output Load Constraints
# Driving Cell Constraints
# Wire Loads
# set_wire_load_mode top
# Other Constraints
