[求助讨论] Labview控制Tektronix MDO4034c时遇到的问题
2435|4
 楼主| leona1392010 发表于 2017-2-17 16:12 | 显示全部楼层 |阅读模式
想请教一下,用PC机的LAN口连接4034c,采集其信号幅值。
用VISA Resource Manager显示仪器已连接,labview编程的instrument drivers 也显示出Tektronix MDO4034c,运行labview里自带的例程就报错,错误代码如下:
-1074003951    Agilent 34401.lvlib:Initialize.vi(ERR)    The ID Query failed.This may mean that you selected the wrong instrument or your instrument did not respond.you may also be using a model that is not officially supported by this driver.if you are sure that you have selected the correct instrument and it is responding,try disabling the ID Query.
看起来是初始化的问题,有人能帮帮我吗?怎么解决这个问题?我的Labview是2015。
songchenping 发表于 2017-2-20 11:28 | 显示全部楼层
只用过USB口连接,
hbzjt2011 发表于 2017-2-20 11:46 | 显示全部楼层
查看一下示波器的访问ID是否正确
songchenping 发表于 2017-2-20 14:03 | 显示全部楼层
你可以在NI MAX里面肯可以识别到示波器吗
顺便读取一下序列号,看是否能正确读取
