msp430怎么使用uart双向接收与发送
1086|17
 楼主| Levenburg 发表于 2017-2-21 20:25 | 显示全部楼层 |阅读模式
UCA0IE |= UCRXIE和UCA1IE |= UCTXIE中断要一起开开吗?这两个好像都是进入USCI_A0_VECTOR中断
dirtwillfly 发表于 2017-2-21 20:34 | 显示全部楼层
看具体应用和资源使用情况阿,根据需要开
Thorald 发表于 2017-2-21 20:45 | 显示全部楼层
发送中断每发送一个字节进入一次中断 接收中断每收到一个字节进入一次中断 在中断函数内可以判断是发送还是接收中断。 使用中断和轮寻都能实现双向发送和接收  具体取决于你的应用
Bjorn 发表于 2017-2-21 20:55 | 显示全部楼层
UCA0IE |=  UCTXIE+UCRXIE;中断函数中判断标志位,根据标志位进行发送接收处理
Rollo 发表于 2017-2-21 21:07 | 显示全部楼层
首先要把接收中断和发送中断区分开
然后再做相应的处理
Stannis 发表于 2017-2-21 21:30 | 显示全部楼层
这是MSP430G2553的UART例程,你可以参考下
//   MSP430G2xx3 Demo - USCI_A0, Ultra-Low Pwr UART 9600 String, 32kHz ACLK
//   Description: This program demonstrates a full-duplex 9600-baud UART using
//   USCI_A0 and a 32kHz crystal.  The program will wait in LPM3, and will
//   respond to a received 'u' character using 8N1 protocol. The response will
//   be the string 'Hello World'.
//   ACLK = BRCLK = LFXT1 = 32768Hz, MCLK = SMCLK = DCO ~1.2MHz
//   Baud rate divider with 32768Hz XTAL @9600 = 32768Hz/9600 = 3.41
//* An external watch crystal is required on XIN XOUT for ACLK *//
//                MSP430G2xx3
//         /|\|              XIN|-
//          | |                 | 32kHz
//          --|RST          XOUT|-
//            |     P1.2/UCA0TXD|------------>
//            |                 | 9600 - 8N1
//            |     P1.1/UCA0RXD|<------------
//   D. Dang
//   Texas Instruments Inc.
//   February 2011
//   Built with CCS Version 4.2.0 and IAR Embedded Workbench Version: 5.10
#include <msp430.h>
const char string1[] = { "Hello World\r\n" };
unsigned int i;
int main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop WDT
  P1DIR = 0xFF;                             // All P1.x outputs
  P1OUT = 0;                                // All P1.x reset
  P2DIR = 0xFF;                             // All P2.x outputs
  P2OUT = 0;                                // All P2.x reset
  P1SEL = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P1SEL2 = BIT1 + BIT2 ;                     // P1.1 = RXD, P1.2=TXD
  P3DIR = 0xFF;                             // All P3.x outputs
  P3OUT = 0;                                // All P3.x reset
  UCA0CTL1 |= UCSSEL_1;                     // CLK = ACLK
  UCA0BR0 = 0x03;                           // 32kHz/9600 = 3.41
  UCA0BR1 = 0x00;                           //
  UCA0MCTL = UCBRS1 + UCBRS0;               // Modulation UCBRSx = 3
  UCA0CTL1 &= ~UCSWRST;                     // **Initialize USCI state machine**
  IE2 |= UCA0RXIE;                          // Enable USCI_A0 RX interrupt
  __bis_SR_register(LPM3_bits + GIE);       // Enter LPM3 w/ int until Byte RXed
#pragma vector=USCIAB0TX_VECTOR
__interrupt void USCI0TX_ISR(void)
  UCA0TXBUF = string1[i++];                 // TX next character
  if (i == sizeof string1 - 1)              // TX over?
    IE2 &= ~UCA0TXIE;                       // Disable USCI_A0 TX interrupt
#pragma vector=USCIAB0RX_VECTOR
__interrupt void USCI0RX_ISR(void)
  if (UCA0RXBUF == 'u')                     // 'u' received?
    i = 0;
    IE2 |= UCA0TXIE;                        // Enable USCI_A0 TX interrupt
pl202 发表于 2017-2-21 21:36 | 显示全部楼层
开串口接收的中断。
pl202 发表于 2017-2-21 21:38 | 显示全部楼层
你的发送中断可以不用开,这样资源可以节约。
嵌入之梦 发表于 2017-2-22 11:31 | 显示全部楼层
双向是什么意思?并行?
soodesyt 发表于 2017-2-22 21:29 | 显示全部楼层
接收中断和发送中断不一样。
soodesyt 发表于 2017-2-22 21:42 | 显示全部楼层
接收能够及时就是要开启接收终端。
tongbu2015 发表于 2017-2-22 23:17 | 显示全部楼层
这个是异步的数据传输的
tongbu2015 发表于 2017-2-22 23:18 | 显示全部楼层
其实涉及到UART的还是蛮简单的,,做仔细些就OK的。
zhangbo1985 发表于 2017-2-22 23:40 | 显示全部楼层
怎想使用同步数据传输的?没整过的
backlugin 发表于 2017-2-24 22:58 | 显示全部楼层
不用开发送中断。
backlugin 发表于 2017-2-24 22:59 | 显示全部楼层
接收中断可以实现开,速度快。
updownq 发表于 2017-2-25 21:11 | 显示全部楼层
发送中断也是这个变量吗?
updownq 发表于 2017-2-25 21:12 | 显示全部楼层
一般都是开启接收中断。
