[DemoCode下载]
NCU029定时器计数
1453|8
dongnanxibei|  楼主 | 2017-2-22 13:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
* [url=home.php?mod=space&uid=288409]@file[/url]     main.c
* [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
* $Revision: 3 $
* $Date: 14/01/28 11:45a $
* [url=home.php?mod=space&uid=247401]@brief[/url]    NUC029 Series Timer Driver Sample Code
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC029xAN.h"
#define PLLCON_SETTING      CLK_PLLCON_50MHz_HXT
#define PLL_CLOCK           50000000
/* Global Interface Variables Declarations        */
volatile uint32_t g_au32TMRINTCount[4] = {0};
/*  Create Counter Source by GPIO PORT2        */
void GeneratePORT2Counter(uint32_t u32Pin, uint32_t u32Counts)
    while(u32Counts--)
        GPIO_PIN_ADDR(2, u32Pin) = 1;
        GPIO_PIN_ADDR(2, u32Pin) = 0;
* @brief       Timer1 IRQ
* @param       None
* [url=home.php?mod=space&uid=266161]@return[/url]      None
* [url=home.php?mod=space&uid=1543424]@Details[/url]     The Timer1 default IRQ, declared in startup_NUC029xAN.s.
void TMR1_IRQHandler(void)
    if(TIMER_GetIntFlag(TIMER1) == 1)
        /* Clear Timer1 time-out interrupt flag */
        TIMER_ClearIntFlag(TIMER1);
        g_au32TMRINTCount[1]++;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable IRC22M clock */
    CLK->PWRCON |= CLK_PWRCON_IRC22M_EN_Msk;
    /* Waiting for IRC22M clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_IRC22M_STB_Msk);
    /* Switch HCLK clock source to HIRC */
    CLK->CLKSEL0 = CLK_CLKSEL0_HCLK_S_HIRC;
    /* Set PLL to Power-down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware.*/
    CLK->PLLCON |= CLK_PLLCON_PD_Msk;
    /* Enable external 12 MHz XTAL */
    CLK->PWRCON |= CLK_PWRCON_XTL12M_EN_Msk;
    /* Enable PLL and Set PLL frequency */
    CLK->PLLCON = PLLCON_SETTING;
    /* Waiting for clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk | CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Switch HCLK clock source to PLL, STCLK to HCLK/2 */
    CLK->CLKSEL0 = CLK_CLKSEL0_STCLK_S_HCLK_DIV2 | CLK_CLKSEL0_HCLK_S_PLL;
    /* Enable peripheral clock */
    CLK->APBCLK = CLK_APBCLK_UART0_EN_Msk | CLK_APBCLK_TMR1_EN_Msk;
    /* Peripheral clock source */
    CLK->CLKSEL1 = CLK_CLKSEL1_UART_S_PLL | CLK_CLKSEL1_TMR1_S_HCLK;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
    SystemCoreClockUpdate();
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD, TXD and T1 */
    SYS->P3_MFP = SYS_MFP_P30_RXD0 | SYS_MFP_P31_TXD0 | SYS_MFP_P35_T1;
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/*  MAIN function        */
int main(void)
    volatile uint32_t u32InitCount;
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %d Hz\n", SystemCoreClock);
    printf("+-------------------------------------------------+\n");
    printf("|    Timer1 External Counter Input Sample Code    |\n");
    printf("+-------------------------------------------------+\n\n");
    printf("# Timer Settings:\n");
    printf("  Timer1: Clock source is HCLK(50 MHz); Continuous counting mode; Interrupt enable;\n");
    printf("          External counter input enable; TCMP is 56789.\n");
    printf("# Connect P2.0 to T1 pin and pull P2.0 High/Low as T1 counter input source.\n\n");
    /* Configure P2.0 as GPIO output pin and pull pin status to Low first */
    GPIO_SetMode(P2, 0, GPIO_PMD_OUTPUT);
    P20 = 0;
    /* Initial Timer1 default setting */
    TIMER_Open(TIMER1, TIMER_CONTINUOUS_MODE, 1);
    /* Configure Timer1 setting for external counter input function */
    TIMER_SELECT_TOUT_PIN(TIMER1, TIMER_TOUT_PIN_FROM_TX_PIN);
    TIMER_SET_PRESCALE_VALUE(TIMER1, 0);
    TIMER_SET_CMP_VALUE(TIMER1, 56789);
    TIMER_EnableEventCounter(TIMER1, TIMER_COUNTER_FALLING_EDGE);
    TIMER_EnableInt(TIMER1);
    /* Enable Timer1 NVIC */
    NVIC_EnableIRQ(TMR1_IRQn);
    /* Clear Timer1 interrupt counts to 0 */
    g_au32TMRINTCount[1] = 0;
    /* Start Timer1 counting */
    TIMER_Start(TIMER1);
    /* To check if TDR of Timer1 must be 0 as default value */
    if(TIMER_GetCounter(TIMER1) != 0)
        printf("Default counter value is not 0. (%d)\n", TIMER_GetCounter(TIMER1));
        /* Stop Timer1 counting */
        TIMER_Close(TIMER1);
        while(1);
    /* To generate one counter event to T1 pin */
    GeneratePORT2Counter(0, 1);
    /* To check if TDR of Timer1 must be 1 */
    while(TIMER_GetCounter(TIMER1) == 0);
    if(TIMER_GetCounter(TIMER1) != 1)
        printf("Get unexpected counter value. (%d)\n", TIMER_GetCounter(TIMER1));
        while(1);
    /* To generate remains counts to T1 pin */
    GeneratePORT2Counter(0, (56789 - 1));
    while(1)
        if((g_au32TMRINTCount[1] == 1) && (TIMER_GetCounter(TIMER1) == 56789))
            printf("Timer1 external counter input function ... PASS.\n");
            break;
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
dongnanxibei|  楼主 | 2017-2-22 13:47 | 只看该作者
通过定时器对外部的输入引进计数。
dongnanxibei|  楼主 | 2017-2-22 13:50 | 只看该作者
看似简单,用起来还是不容易的,好几个函数。
xixi2017| | 2017-4-20 17:31 | 只看该作者
定时器用于计数。
捉虫天师| | 2017-4-20 22:54 | 只看该作者
这个地方写的好,通过判断是否置位,然后再清理标志,虽然知道中断后肯定是置位的。
yiyigirl2014| | 2017-4-21 15:49 | 只看该作者
能一次提供个完整的工程不
zhuomuniao110| | 2017-4-21 18:58 | 只看该作者
每次品读例程都有不小的收货。
598330983| | 2017-4-22 19:23 | 只看该作者
这个设置要好好看看官方的教程怎么讲的, 怎么个流程。
heisexingqisi| | 2017-4-23 15:12 | 只看该作者
下降沿触发
