[技术问题解答] 1.2GHzi mx6q,u-boot启动失败,mmc init failed
2332|1
 楼主| dirtyrain 发表于 2017-3-1 10:35 | 显示全部楼层 |阅读模式
之前用的4.5版本emmc 8G,可以正常启动,现在换了一个32g的5.0版本emmc,u-boot启动失败,请问这是为什么呢????
log如下:
H2014.04-svn1 (Feb 27 2017 - 22:03:47)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
CPU:   Temperature 22 C, calibration data: 0x5404c769
Reset cause: POR
Board: MX6-SabreSD
I2C:   ready
DRAM:  1 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
MMC init failed
Using default environment
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In:    serial
Out:   serial
Err:   serial
Found PFUZE100 deviceid=10,revid=21
check_and_clean: reg 0, flag_set 0
Fastboot: Normal
flash target is MMC:2
MMC card init failed!
** Block device MMC 2 not supported
Net:   Phy not found
PHY reset timed out
FEC [PRIME]
Warning: failed to set MAC address
Normal Boot
Hit any key to stop autoboot:  1  0
booti mmc2
fastboot is in init......USB Mini b cable Connected!
fastboot initialized
USB_SUSPEND
USB_RESET
USB_PORT_CHANGE 0x4
USB_RESET
USB_PORT_CHANGE 0x4
小番茄 发表于 2017-3-15 15:04 | 显示全部楼层
你好, 请问你这问题解决了吗?我现在也遇到这个问题了
