这两天刚看psoc3,总看到Component,到底什么是Component呀
967|10
 楼主| llljh 发表于 2017-3-5 21:39 | 显示全部楼层 |阅读模式
xxrs 发表于 2017-3-5 21:41 | 显示全部楼层
我一般翻译成组件或元件,几乎所有单片机内部都会集成一些功能组件
 楼主| llljh 发表于 2017-3-5 21:42 | 显示全部楼层
能举个例子吗?
yinxiangh 发表于 2017-3-5 21:44 | 显示全部楼层
例如ADC,UART,USB等等啊
chenjunt 发表于 2017-3-5 21:47 | 显示全部楼层
PSOC里的组件库是我见过最为丰富的
morrisk 发表于 2017-3-5 21:49 | 显示全部楼层
而且这些组件可以自由选用
xxmmi 发表于 2017-3-5 21:51 | 显示全部楼层
并且所选组件之间的路由也是非常灵活的
zwll 发表于 2017-3-5 21:53 | 显示全部楼层
说的是,psoc有很多可编程的数字和模拟资源,可以设计成你所需要的Component元件,这就是psoc的魅力之处。
juventus9554 发表于 2017-3-5 21:56 | 显示全部楼层
要是用过psoc1的话,和user module类似。
dingy 发表于 2017-3-5 21:57 | 显示全部楼层
官方解释:
A component is similar to a fixed function peripheral found in traditional microcontrollers. The components support many of the common microcontroller peripherals such as ADC, DAC, I2C, and SPI as well as application specific features such as LCDs, bootloaders and LED control. The advantage of PSoC is that you have the ability to place and configure the components on the target device. Instead of choosing a device for its features, PSoC embedded developers can tailor PSoC to fit their application. PSoC Creator supports a mixed signal environment providing both digital and analog components. Creator comes equipped with extensible code for each component in the form of APIs. The component APIs provide out-of-the-box code that allows the user to implement peripheral actions using simple function calls reducing development time. For more information on each component see the component datasheet that details the functionality, APIs, and specifications.
 楼主| llljh 发表于 2017-3-5 22:02 | 显示全部楼层
哦,那我就知道怎么回事了,多谢大家,结贴了哈
