参考
* Function Name: customize_itoa
* Summary:
* This is a simple function to convert int to ascii code
* Parameters:
* Return:
char *customize_itoa(int num,char *str,int radix)
char index[]="0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ";
unsigned unum;
int i=0,j,k;
if(radix==10&&num<0)
unum=(unsigned)-num;
str[i++]='-';
else unum=(unsigned)num;
do
str[i++]=index[unum%(unsigned)radix];
unum/=radix;
}while(unum);
str[i]='\0';
if(str[0]=='-') k=1;
else k=0;
char temp;
for(j=k;j<=(i-k-1)/2.0;j++)
temp=str[j];
str[j]=str[i-j-1];
str[i-j-1]=temp;
return str;
