有源差分探头帮你解决后顾之优!
1790|1
sbyceto|  楼主 | 2008-12-26 11:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Specifications
Type     PT-8101          PT-8110
Bandwidth        100MHz
Input Max.Voltage    ±700V             ±1400V
Attenuation    1:10/100           1:100/1000
Accuracy    ±2%
Input Impedance    4MΩ//7pF each side to ground
Swing(into 50kΩ load)    ±7v
Offset(typical)    <±5mV
Noise(typical)    0.9mVrms
Source Impedance(typical)    50Ω
Features:
   1.Up to±1400V(DC+Peak AC)Differential and Common Mode
   2.Bandwidth up to 100MHz
   3.Safety Certifed
