求高手帮忙看一下这个步进电机加速程序
3650|4
 楼主| ouyangqu 发表于 2010-4-19 12:53 | 显示全部楼层 |阅读模式
俺用的是stm32f10xxE
编译通过,但是电机转不动,中断也进不去,i和pulse的值一直不变。
#include "stm32f10x.h"
#include"main.h"
int i;
int pulse=0;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
ErrorStatus HSEStartUpStatus;
void NVIC_Configuration(void);
void RCC_Configuration(void);
void TIM4_Configuration(void);
void GPIO_Configuration(void);
#define VECT_TAB_RAM
int main(void)
   i=0;
  #ifdef DEBUG
    debug();/*[初始化外围设备指针]*/
  #endif
  RCC_Configuration(); //初始化时钟与复位
  NVIC_Configuration();//初始化中断嵌套
  TIM4_Configuration();//初始化定时器
  GPIO_Configuration();
  GPIO_WriteBit(GPIOD, GPIO_Pin_7, (BitAction)(0));
  GPIO_WriteBit(GPIOD, GPIO_Pin_6, (BitAction)(0));  //DCY1 DCY2为00,即Normal %0 DECAY
  GPIO_WriteBit(GPIOE, GPIO_Pin_7, (BitAction)(1));
  GPIO_WriteBit(GPIOB, GPIO_Pin_1, (BitAction)(0));      //M1M2为10,即1-2-phase
  GPIO_WriteBit(GPIOA, GPIO_Pin_4, (BitAction)(1));  //正向旋转
  GPIO_WriteBit(GPIOB, GPIO_Pin_0, (BitAction)(0));
  GPIO_WriteBit(GPIOC, GPIO_Pin_5, (BitAction)(1));  //TQ1 TQ2为01,即Current Ratio为50%
  GPIO_WriteBit(GPIOA, GPIO_Pin_7, (BitAction)(1));  //StepReset位
  GPIO_WriteBit(GPIOC, GPIO_Pin_4, (BitAction)(1));  //StepEn 使能位
  while(1)
     if(i<4500)
       pulse=4999-i;
       TIM_SetAutoreload(TIM4,pulse);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_7;   //PA的3.4.7接CLK,CW/CCW,StepReset
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
  GPIO_Init(GPIOA,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin= GPIO_Pin_5 | GPIO_Pin_6;   //PA的6.7接Protect和Mo
  GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4 | GPIO_Pin_5;   //PC的4.5接StepEn和TQ2
  GPIO_Init(GPIOC,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_6;   //PB的0.1接TQ1和M2
  GPIO_Init(GPIOB,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_7;   //PE7接M1
  GPIO_Init(GPIOE,&GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin=GPIO_Pin_6 | GPIO_Pin_7;   //PD的67接DCY2和DCY1
  GPIO_Init(GPIOD,&GPIO_InitStructure);
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;  //设置TIM4通道输入中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; /*配置优先级组*/
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;      /*允许TIM4全局中断*/
  NVIC_Init(&NVIC_InitStructure);
  TIM_SetCounter( TIM4, 0x0000);
  TIM_ClearFlag(TIM4, TIM_FLAG_Update);        /*清除更新标志位*/
  TIM_ClearITPendingBit(TIM4, TIM_FLAG_Update); //清除TIM4等待中断更新中断标志位
  TIM_ARRPreloadConfig(TIM4, ENABLE);        /*预装载寄存器的内容被立即传送到影子寄存器 */
  TIM_ITConfig(TIM4, TIM_IT_Update, ENABLE); //使能TIM4的更新
  TIM_TimeBaseStructure.TIM_Period = 4999;        //设定的最大计数值5000,最大计数值是0xffff
  TIM_TimeBaseStructure.TIM_Prescaler = 71;     //分频72
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;     // 时钟分割
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //计数方向向上计数
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_Cmd(TIM4, ENABLE);       //TIM4 enable counter
  RCC_DeInit();
  RCC_HSEConfig(RCC_HSE_ON);
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    FLASH_SetLatency(FLASH_Latency_2);
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    RCC_PCLK2Config(RCC_HCLK_Div1);
    RCC_PCLK1Config(RCC_HCLK_Div2);
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource() != 0x08)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                                | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE,ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE); //在开启时钟里一定要打开TIM4的时钟
void Delay(u32 nCount)
  do
  while(nCount--);
main.h内容
#define StepEnPin GPIO_Pin_4
extern int i;
extern int pulse;
extern TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
void Delay(u32 nCount);
中断程序
void TIM4_IRQHandler(void)
  if (TIM_GetITStatus(TIM4, TIM_IT_Update) == SET)
    i=i+1;
    GPIO_WriteBit(GPIOA,GPIO_Pin_3,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOA,GPIO_Pin_3)));
     if(i>=4500)
     i=4500;
speedup.rar
374.1 KB, 下载次数: 45
 楼主| ouyangqu 发表于 2010-4-19 16:16 | 显示全部楼层
究竟应该用什么样的方式提问呢?
txcy 发表于 2010-4-19 21:52 | 显示全部楼层
中断进不去,首先考虑中断的配置是否正确
司徒老鹰 发表于 2010-4-19 23:07 | 显示全部楼层
自己一点一点慢慢查吧
 楼主| ouyangqu 发表于 2010-4-20 11:03 | 显示全部楼层
怎么样查呢? 4# 司徒老鹰
