[Actel FPGA] 管脚分配时出现问题
3511|2
 楼主| 6019赵文 发表于 2010-4-25 19:16 | 显示全部楼层 |阅读模式
在做电压监控时,I/O分配时出现一下错误:
Starting Prelayout Check...
Error: PRL13: Cannot place the instance rst_pad on the Lower Right quadrant      locations because
       the instance flash_inst/NVM_INST_CALIBRATIONDATA connected to the clock net cannot be assigned to a quadrant.
       This instance must be placed on a middle left or middle right global locations.
Completed Prelayout Check
Running global checker.
Error: PLC002: No legal assignment exists for global net rst_c.
Info: Unlocking the driver or removing the region constraint for net rst_c may help to satisfy the global net assignment.
Error: PLC005: Automatic global net placement failed.
请问这是什么问题
linux1 发表于 2010-4-25 19:19 | 显示全部楼层
是说你的rst引脚只能分配到一个时钟引脚上,你看RTC实验的综合部分,就可以了。
 楼主| 6019赵文 发表于 2010-4-25 19:52 | 显示全部楼层
好了,谢谢拉
