[应用相关] STM32DAC和PWM时钟不同步
972|0
 楼主| 可可球 发表于 2017-3-14 22:09 | 显示全部楼层 |阅读模式
我利用stm32L4芯片内部DAC产生正弦波,再利用timer的PWM产生方波,可是利用示波器观察发现,两个波形不同步,开发库是HAL库,求解决方案,已经困扰我两个星期了。。。。我之前利用stm32F1的标准库产生的波形是同步的。。。部分代码如下:timer配置:
void        TIM1_Config(void)
TimHandle.Instance = TIM1;
  TimHandle.Init.Prescaler         = uhPrescalerValue1;
  TimHandle.Init.Period            = PERIOD_VALUE1;
  TimHandle.Init.ClockDivision     = 0;
  TimHandle.Init.CounterMode       = TIM_COUNTERMODE_UP;
  TimHandle.Init.RepetitionCounter = 0;
if (HAL_TIM_PWM_Init(&TimHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
  sConfig.OCMode       = TIM_OCMODE_PWM1;
  sConfig.OCPolarity   = TIM_OCPOLARITY_HIGH;
  sConfig.OCFastMode   = TIM_OCFAST_DISABLE;
  sConfig.OCNPolarity  = TIM_OCNPOLARITY_HIGH;
  sConfig.OCNIdleState = TIM_OCNIDLESTATE_RESET;
  sConfig.OCIdleState  = TIM_OCIDLESTATE_RESET;
  sConfig.Pulse = PULSE1_VALUE1;
  if (HAL_TIM_PWM_ConfigChannel(&TimHandle, &sConfig, TIM_CHANNEL_1) != HAL_OK)
    /* Configuration Error */
    Error_Handler();
  if (HAL_TIM_PWM_Start(&TimHandle, TIM_CHANNEL_1) != HAL_OK)
    /* PWM Generation Error */
    Error_Handler();
DAC时钟配置:
void TIM6_Config(void)
  TIM_MasterConfigTypeDef sMasterConfig;
  htim.Instance = TIM6;
  htim.Init.Period            = PERIOD_VALUE6;
  htim.Init.Prescaler         = uhPrescalerValue2;
  htim.Init.ClockDivision     = 0;
  htim.Init.CounterMode       = TIM_COUNTERMODE_UP;
  htim.Init.RepetitionCounter = 0;
  HAL_TIM_Base_Init(&htim);
  sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE;//TIM_TRGO_ENABLE;//
  sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE;
  HAL_TIMEx_MasterConfigSynchronization(&htim, &sMasterConfig);
  HAL_TIM_Base_Start(&htim);
