[DemoCode下载] M0518的PLL时钟输出方法
1874|11
 楼主| gejigeji521 发表于 2017-3-25 18:04 | 显示全部楼层 |阅读模式
  1. /****************************************************************************
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * $Revision: 3 $
  5. * $Date: 14/12/25 10:24a $
  6. * @brief
  7. *           Change system clock to different PLL frequency and output system clock from CLKO pin.
  8. *
  9. * @note
  10. * Copyright (C) 2011 Nuvoton Technology Corp. All rights reserved.
  11. *
  12. ******************************************************************************/
  13. #include <stdio.h>
  14. #include "M0518.h"
  15. #define PLL_CLOCK   50000000
  16. #define SIGNATURE       0x125ab234
  17. #define FLAG_ADDR       0x20000FFC
  18. /*---------------------------------------------------------------------------------------------------------*/
  19. /* Define functions prototype        */
  20. /*---------------------------------------------------------------------------------------------------------*/
  21. int32_t pi(void);
  22. void Delay(uint32_t x);
  23. void SYS_PLL_Test(void);
  24. void SYS_Init(void);
  25. void UART0_Init(void);
  26. int32_t main(void);
  27. /*---------------------------------------------------------------------------------------------------------*/
  28. /*  Simple calculation test function        */
  29. /*---------------------------------------------------------------------------------------------------------*/
  30. #define PI_NUM  256
  31. int32_t f[PI_NUM + 1];
  32. uint32_t piTbl[19] =
  33. {
  34.     3141,
  35.     5926,
  36.     5358,
  37.     9793,
  38.     2384,
  39.     6264,
  40.     3383,
  41.     2795,
  42.     288,
  43.     4197,
  44.     1693,
  45.     9937,
  46.     5105,
  47.     8209,
  48.     7494,
  49.     4592,
  50.     3078,
  51.     1640,
  52.     6284
  53. };
  54. int32_t piResult[19];
  55. int32_t pi(void)
  56. {
  57.     int32_t i, i32Err;
  58.     int32_t a = 10000, b = 0, c = PI_NUM, d = 0, e = 0, g = 0;
  59.     for(; b - c;)
  60.         f[b++] = a / 5;
  61.     i = 0;
  62.     for(; d = 0, g = c * 2; c -= 14,/*printf("%.4d\n",e+d/a),*/ piResult[i++] = e + d / a, e = d % a)
  63.     {
  64.         if(i == 19)
  65.             break;
  66.         for(b = c; d += f[b] * a, f[b] = d % --g, d /= g--, --b; d *= b);
  67.     }
  68.     i32Err = 0;
  69.     for(i = 0; i < 19; i++)
  70.     {
  71.         if(piTbl[i] != piResult[i])
  72.             i32Err = -1;
  73.     }
  74.     return i32Err;
  75. }
  76. void Delay(uint32_t x)
  77. {
  78.     int32_t i;
  79.     for(i = 0; i < x; i++)
  80.     {
  81.         __NOP();
  82.         __NOP();
  83.     }
  84. }
  85. uint32_t g_au32PllSetting[] =
  86. {
  87.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(25) | CLK_PLLCON_NO_4,  /* PLL = 25MHz */
  88.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(29) | CLK_PLLCON_NO_4,  /* PLL = 29MHz */
  89.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(33) | CLK_PLLCON_NO_4,  /* PLL = 33MHz */
  90.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(37) | CLK_PLLCON_NO_4,  /* PLL = 37MHz */
  91.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(41) | CLK_PLLCON_NO_4,  /* PLL = 41MHz */
  92.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(45) | CLK_PLLCON_NO_4,  /* PLL = 45MHz */
  93.     CLK_PLLCON_PLL_SRC_HXT | CLK_PLLCON_NR(3) | CLK_PLLCON_NF(49) | CLK_PLLCON_NO_4   /* PLL = 49MHz */
  94. };
  95. void SYS_PLL_Test(void)
  96. {
  97.     int32_t  i;
  98.     /*---------------------------------------------------------------------------------------------------------*/
  99.     /* PLL clock configuration test        */
  100.     /*---------------------------------------------------------------------------------------------------------*/
  101.     printf("\n-------------------------[ Test PLL ]-----------------------------\n");
  102.     for(i = 0; i < sizeof(g_au32PllSetting) / sizeof(g_au32PllSetting[0]) ; i++)
  103.     {
  104.         /* Switch HCLK clock source to HXT and HCLK source divide 1 */
  105.         CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HXT, CLK_CLKDIV_HCLK(1));
  106.         /* Set PLL to power down mode and PLL_STB bit in CLKSTATUS register will be cleared by hardware. */
  107.         CLK_DisablePLL();
  108.         /* Set PLL frequency */
  109.         CLK->PLLCON = g_au32PllSetting[i];
  110.         /* Waiting for PLL clock ready */
  111.         CLK_WaitClockReady(CLK_CLKSTATUS_PLL_STB_Msk);
  112.         /* Switch HCLK clock source to PLL */
  113.         CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_PLL, CLK_CLKDIV_HCLK(1));
  114.         printf("  Change system clock to %d Hz ...................... ", SystemCoreClock);
  115.         /* Output selected clock to CKO, CKO Clock = HCLK / 2^(1 + 1) */
  116.         CLK_EnableCKO(CLK_CLKSEL2_FRQDIV_S_HCLK, 1, 0);
  117.         /* The delay loop is used to check if the CPU speed is increasing */
  118.         Delay(0x400000);
  119.         if(pi())
  120.         {
  121.             printf("[FAIL]\n");
  122.         }
  123.         else
  124.         {
  125.             printf("[OK]\n");
  126.         }
  127.         /* Disable CKO clock */
  128.         CLK_DisableCKO();
  129.     }
  130. }
  131. void SYS_Init(void)
  132. {
  133.     /*---------------------------------------------------------------------------------------------------------*/
  134.     /* Init System Clock        */
  135.     /*---------------------------------------------------------------------------------------------------------*/
  136.     /* Enable Internal RC 22.1184MHz clock */
  137.     CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
  138.     /* Waiting for Internal RC clock ready */
  139.     CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
  140.     /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
  141.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  142.     /* Enable external XTAL 12MHz clock */
  143.     CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
  144.     /* Waiting for external XTAL clock ready */
  145.     CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
  146.     /* Set core clock as PLL_CLOCK from PLL */
  147.     CLK_SetCoreClock(PLL_CLOCK);
  148.     /* Enable UART module clock */
  149.     CLK_EnableModuleClock(UART0_MODULE);
  150.     /* Select UART module clock source */
  151.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_HXT, CLK_CLKDIV_UART(1));
  152.     /*---------------------------------------------------------------------------------------------------------*/
  153.     /* Init I/O Multi-function        */
  154.     /*---------------------------------------------------------------------------------------------------------*/
  155.     /* Set GPB multi-function pins for UART0 RXD(PB.0), TXD(PB.1) and Clock Output(PB.8) */
  156.     SYS->GPB_MFP &= ~(SYS_GPB_MFP_PB0_Msk | SYS_GPB_MFP_PB1_Msk | SYS_GPB_MFP_PB8_Msk);
  157.     SYS->ALT_MFP &= ~SYS_ALT_MFP_PB8_Msk;
  158.     SYS->ALT_MFP3 &= ~SYS_ALT_MFP3_PB8_Msk;
  159.     SYS->GPB_MFP |= (SYS_GPB_MFP_PB0_UART0_RXD | SYS_GPB_MFP_PB1_UART0_TXD | SYS_GPB_MFP_PB8_CLKO);
  160.     SYS->ALT_MFP |=  SYS_ALT_MFP_PB8_CLKO;
  161.     SYS->ALT_MFP3 |= SYS_ALT_MFP3_PB8_CLKO;
  162. }
  163. void UART0_Init(void)
  164. {
  165.     /*---------------------------------------------------------------------------------------------------------*/
  166.     /* Init UART        */
  167.     /*---------------------------------------------------------------------------------------------------------*/
  168.     /* Reset UART0 module */
  169.     SYS_ResetModule(UART0_RST);
  170.     /* Configure UART0 and set UART0 Baudrate */
  171.     UART_Open(UART0, 115200);
  172. }
  173. /*---------------------------------------------------------------------------------------------------------*/
  174. /* MAIN function        */
  175. /*---------------------------------------------------------------------------------------------------------*/
  176. int32_t main(void)
  177. {
  178.     uint32_t u32data;
  179.     /* In end of main function, program issued CPU reset and write-protection will be disabled. */
  180.     if(SYS_IsRegLocked() == 0)
  181.         SYS_LockReg();
  182.     /* Unlock protected registers */
  183.     SYS_UnlockReg();
  184.     /* Init System, peripheral clock and multi-function I/O */
  185.     SYS_Init();
  186.     /* Lock protected registers */
  187.     SYS_LockReg();
  188.     /* Init UART0 for printf */
  189.     UART0_Init();
  190.     printf("\n\nCPU [url=home.php?mod=space&uid=72445]@[/url] %dHz\n", SystemCoreClock);
  191.     /*
  192.         This sample code will show some function about system manager controller and clock controller:
  193.         1. Read PDID
  194.         2. Get and clear reset source
  195.         3. Setting about BOD
  196.         4. Change system clock depended on different PLL settings
  197.         5. Output system clock from CKO pin, and the output frequency = system clock / 4
  198.     */
  199.     printf("+----------------------------------------+\n");
  200.     printf("|    M0518 System Driver Sample Code    |\n");
  201.     printf("+----------------------------------------+\n");
  202.     if(M32(FLAG_ADDR) == SIGNATURE)
  203.     {
  204.         printf("  CPU Reset success!\n");
  205.         M32(FLAG_ADDR) = 0;
  206.         printf("  Press any key to continue ...\n");
  207.         getchar();
  208.     }
  209.     /*---------------------------------------------------------------------------------------------------------*/
  210.     /* Misc system function test        */
  211.     /*---------------------------------------------------------------------------------------------------------*/
  212.     /* Read Part Device ID */
  213.     printf("Product ID 0x%x\n", SYS_ReadPDID());
  214.     /* Get reset source from last operation */
  215.     u32data = SYS_GetResetSrc();
  216.     printf("Reset Source 0x%x\n", u32data);
  217.     /* Clear reset source */
  218.     SYS_ClearResetSrc(u32data);
  219.     /* Unlock protected registers for Brown-Out Detector settings */
  220.     SYS_UnlockReg();
  221.     /* Check if the write-protected registers are unlocked before BOD setting and CPU Reset */
  222.     if(SYS_IsRegLocked() == 0)
  223.     {
  224.         printf("Protected Address is Unlocked\n");
  225.     }
  226.     /* Enable Brown-Out Detector, and set Brown-Out Detector voltage 2.7V */
  227.     SYS_EnableBOD(SYS_BODCR_BOD_INTERRUPT_EN, SYS_BODCR_BOD_VL_2_7V);
  228.     /* Enable BOD IRQ */
  229.     NVIC_EnableIRQ(BOD_IRQn);
  230.     /* Enable Low Voltage Reset function */
  231.     SYS_ENABLE_LVR();
  232.     /* Run PLL Test */
  233.     SYS_PLL_Test();
  234.     /* Write a signature work to SRAM to check if it is reset by software */
  235.     M32(FLAG_ADDR) = SIGNATURE;
  236.     printf("\n\n  >>> Reset CPU <<<\n");
  237.     /* Waiting for message send out */
  238.     UART_WAIT_TX_EMPTY(UART0);
  239.     /* Switch HCLK clock source to Internal RC 22.1184MHz clock and HCLK source divide 1 */
  240.     CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
  241.     /* Set PLL to Power down mode and HW will also clear PLL_STB bit in CLKSTATUS register */
  242.     CLK_DisablePLL();
  243.     /* Reset CPU */
  244.     SYS_ResetCPU();
  245. }
huangcunxiake 发表于 2017-3-25 21:39 | 显示全部楼层
天灵灵地灵灵 发表于 2017-3-25 22:20 | 显示全部楼层
PLL可以提供高速的时钟信号,输出可以给使用高速时钟的设备。
天灵灵地灵灵 发表于 2017-3-25 22:57 | 显示全部楼层
做个可调的更给力,通过两个IO实现增或者减小。。
玛尼玛尼哄 发表于 2017-3-25 23:46 | 显示全部楼层
一般单片机都有个时钟输出接口。
玛尼玛尼哄 发表于 2017-3-26 00:17 | 显示全部楼层
一般晶振电路时钟频率都比较低,通过PLL锁相电路把频率抬高,产生高频信号。
dongnanxibei 发表于 2017-3-27 11:32 | 显示全部楼层
piTbl这个数组不是很明白。
稳稳の幸福 发表于 2017-3-27 15:08 | 显示全部楼层
PLL还可以玩超频。
598330983 发表于 2017-3-31 22:07 来自手机 | 显示全部楼层
如果单片机系统挂的有什么需要高速晶振的外设就可以通过这个提供时钟
zhuotuzi 发表于 2017-4-5 19:34 | 显示全部楼层
一个系统如果需要多个时钟信号,就可以通过这个输出给需要高频时钟的电路。
huangcunxiake 发表于 2017-4-6 20:06 | 显示全部楼层
设置PLL前,先关闭再配置
 楼主| gejigeji521 发表于 2017-4-15 08:16 | 显示全部楼层
关闭是为了设置好后统一开启。
