[i.MX] imx6 lvds 设备树配置显示
3849|2
 楼主| myfish1235 发表于 2017-3-28 14:27 | 显示全部楼层 |阅读模式
LVDS, mx, TI, AC, rc
imx6dl下的设备树配置:
        mxcfb1: fb@0 {
                compatible = "fsl,mxc_sdc_fb";
                disp_dev = "ldb";
                interface_pix_fmt = "RGB666";
                default_bpp = <16>;
                int_clk = <0>;
                late_init = <0>;
                status = "disabled";
&ldb {
        status = "okay";
        lvds-channel@0 {
                fsl,data-mapping = "spwg";
                fsl,data-width = <18>;
                status = "okay";
                display-timings {
                        native-mode = <&timing0>;
                        timing0: hsd100pxn1 {
                                clock-frequency = <65000000>;
                                hactive = <1024>;
                                vactive = <600>;
                                hback-porch = <110>;
                                hfront-porch = <110>;
                                vback-porch = <17>;
                                vfront-porch = <17>;
                                hsync-len = <100>;
                                vsync-len = <4>;
        lvds-channel@1 {
                primary;
                status = "okay";
                display-timings {
                        native-mode = <&timing1>;
                        timing1: hsd100pxn1 {
                                hactive = <1024>;
                                vactive = <600>;
                                vback-porch = <17>;
                                hsync-len = <100>;
                                vsync-len = <4>;
&ldb {
        lvds-channel@0 {
                crtc = "ipu1-di0";
        lvds-channel@1 {
                crtc = "ipu1-di1";
屏幕没有图像输出,只有条纹
 楼主| myfish1235 发表于 2017-3-28 18:43 | 显示全部楼层
自己刷一下存在
 楼主| myfish1235 发表于 2017-3-29 16:13 | 显示全部楼层
结贴喽,上述关于ldb和fb的设置没什么错误,主要原因是lcd没有上电,晕。。。
