Size and Cost Optimized Binary Module Reference Design Using Digital Isolator
1543|15
 楼主| dirtwillfly 发表于 2017-4-8 22:37 | 显示全部楼层 |阅读模式
描述
The TIDA-00847 TI design showcases space and cost optimized architecture for a 4 channel DC input binary module  with improved measurement accuracy and status indication using only two TI products simplifying system design. MCU based binary module improves measurement resolution of binary input resulting in improved system performance including accurate and repeatable fault indications and  eliminates the need for multiple hardware versions (use same design for multiple nominal voltage inputs)  reducing design, testing, manufacturing and field support efforts. In this TI design 4 input channels are configured as group isolated inputs to minimize cost per channel. A 10-bit analog-to-digital converter (ADC) measures the DC inputs with in ±3% ±1 V accuracy over wide range. Pre-compliance tests for EMI and EMC have been performed.
特性
  • Binary input module design based on reinforced isolation  ISOW7841 or ISOW7841F, digital isolator with integrated high efficiency, power converter with soft-start and 75 mA current output (quad with various configurations for GPIO or SPI or UART interface) simplifying system design
  • MSP430G2332 or MSP430FR2111, MCU based 4 channel DC input or 2-channel AC or DC voltage input measurement type binary Input module
  • ISOW7841 provides 46% efficiency with output ripple of 100mV for 70mA load (pkpk)
  • Accuracy <=  ±3% of measured value ±1 V (programming resolution or step size)
  • Meets pre-compliance tests for  EMI and EMC as per IEC61000-4 and CISPR22 standards
 楼主| dirtwillfly 发表于 2017-4-8 22:41 | 显示全部楼层
 楼主| dirtwillfly 发表于 2017-4-8 22:42 | 显示全部楼层
i1mcu 发表于 2017-4-9 16:35 | 显示全部楼层
看着很高深的资料。
i1mcu 发表于 2017-4-9 16:36 | 显示全部楼层
 楼主| dirtwillfly 发表于 2017-4-9 20:38 | 显示全部楼层
内容也是英文资料。
英文的有问题?
gygp 发表于 2017-4-11 21:51 | 显示全部楼层
英文看不懂。
gygp 发表于 2017-4-11 21:54 | 显示全部楼层
看着很高深的资料。
资料很好,但是英文资料看不懂。
vivilzb1985 发表于 2017-4-11 23:11 | 显示全部楼层
全英文的,看的头大的
 楼主| dirtwillfly 发表于 2017-4-12 07:51 | 显示全部楼层
232321122 发表于 2017-4-16 16:35 | 显示全部楼层
谢谢版主分享资料。
232321122 发表于 2017-4-16 16:36 | 显示全部楼层
内容也是英文资料。
开启翻译功能就可以。
lzbf 发表于 2017-4-23 22:23 | 显示全部楼层
内容也是英文资料。
这个资料有什么问题?
lzbf 发表于 2017-4-23 22:25 | 显示全部楼层
开启翻译功能就可以。
其实既能够学习英语又能够学习技能。
myiclife 发表于 2017-4-24 22:20 | 显示全部楼层
跟着学习一下。
myiclife 发表于 2017-4-24 22:23 | 显示全部楼层
100A 电流源参考设计
个人签名:欢迎进入TI MCU论坛      21ic TI技术交流1群:61549143(已满),  21ic TI技术交流2群:311421422 我的博客:http://blog.timcu.com/
1203
