[i.MX] bitbake编译SDK时报错,该如何解决?
1188|1
 楼主| hellohaotian 发表于 2017-4-13 15:27 | 显示全部楼层 |阅读模式
Loaded 2524 entries from dependency cache.
NOTE: Resolving any missing task queue dependencies
NOTE: multiple providers are available for jpeg (jpeg, libjpeg-turbo)
NOTE: consider defining a PREFERRED_PROVIDER entry to match jpeg
NOTE: multiple providers are available for runtime libgl-mesa-dev (mesa, mesa-gl)
NOTE: consider defining a PREFERRED_PROVIDER entry to match libgl-mesa-dev
NOTE: multiple providers are available for runtime libglapi (mesa, mesa-gl)
NOTE: consider defining a PREFERRED_PROVIDER entry to match libglapi
Build Configuration:
BB_VERSION        = "1.24.0"
BUILD_SYS         = "x86_64-linux"
NATIVELSBSTRING   = "Ubuntu-14.04"
TARGET_SYS        = "arm-poky-linux-gnueabi"
MACHINE           = "imx6qsabresd"
DISTRO            = "poky"
DISTRO_VERSION    = "1.7"
TUNE_FEATURES     = "arm armv7a vfp neon callconvention-hard cortexa9"
TARGET_FPU        = "vfp-neon"
meta
meta-yocto        = "(nobranch):f20e4c0cf6ddb29a1aad6e7b095e1472e81d330c"
meta-oe
meta-multimedia   = "(nobranch):7bbacd0023fa1111da94ba0b2aafd7d872301ffe"
meta-fsl-arm      = "(nobranch):b74e5e690d8d4e149ea9de3f0fcca37bad93935f"
meta-fsl-arm-extra = "(nobranch):b32528c10caac5e85f2b5efe0e5b95322dd68ace"
meta-fsl-demos    = "(nobranch):48cb0bcdd226d2e7eee1fdc222713e1dff93342c"
meta-fsl-arm
meta-fsl-demos    = "(nobranch):9a2973abf0d1de9742561c3af57de7b8cba7063a"
meta-browser      = "(nobranch):63963cc56c8d0291779693e62b66cb16e5c86883"
meta-gnome
meta-networking
meta-python
meta-ruby
meta-filesystems  = "(nobranch):7bbacd0023fa1111da94ba0b2aafd7d872301ffe"
meta-qt5          = "(nobranch):41c5daa84af4466bfc9aa61f6f772c68470a628b"
meta-fsl-bluez    = "(nobranch):9a2973abf0d1de9742561c3af57de7b8cba7063a"
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: Function failed: do_compile (log file is located at /home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/temp/log.do_compile.67770)
ERROR: Logfile of failure stored in: /home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/temp/log.do_compile.67770
Log data follows:
| DEBUG: SITE files ['endian-little', 'common-linux', 'common-glibc', 'bit-64', 'x86_64-linux', 'common']
| DEBUG: Executing shell function do_compile
| NOTE: make -j 2 all-gcc configure-target-libgcc
| make[1]: Entering directory `/home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/gcc-4.9.1/build.x86_64-linux.x86_64-pokysdk-linux/intl'
| make[1]: Nothing to be done for `all'.
| make[1]: Leaving directory `/home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/gcc-4.9.1/build.x86_64-linux.x86_64-pokysdk-linux/intl'
| make[1]: Entering directory `/home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/gcc-4.9.1/build.x86_64-linux.x86_64-pokysdk-linux/libiberty'
| make[2]: Entering directory `/home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/gcc-4.9.1/build.x86_64-linux.x86_64-pokysdk-linux/libiberty/testsuite'
| make[2]: Nothing to be done for `all'.
| make[2]: Leaving directory `/home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/gcc-4.9.1/build.x86_64-linux.x86_64-pokysdk-linux/libiberty/testsuite'
| make[1]: Leaving directory `/home/vmuser/mx6x/fsl-release-bsp/imx6qsabresd-fb/tmp/work/x86_64-pokysdk-linux/gcc-crosssdk-initial-x86_64/4.9.1-r0/gcc-4.9.1/build.x86_64-linux.x86_64-pokysdk-linux/libiberty'
mahongtu 发表于 2017-7-14 17:17 | 显示全部楼层
这个问题好多啊 我也是卡在这
