如何增加mysql的最大连接数
535|0
 楼主| 爱笑的panhutu 发表于 2017-4-15 17:43 | 显示全部楼层 |阅读模式
mysql, se, IO, ST, ni
修改my.ini
# The maximum amount of concurrent sessions the MySQL server will
# allow. One of these connections will be reserved for a user with
# SUPER privileges to allow the administrator to login even if the
# connection limit has been reached.
max_connections=100
将它改成更大的数值,如500
转自江苏三艾网络
