再读BULK IN却无法读到fpga取反回传的数据
698|6
 楼主| chenjunt 发表于 2017-4-15 20:40 | 显示全部楼层 |阅读模式
上位机先读BULK IN,报超时退出->上位机写BULK OUT->上位机再读BULK IN则可以读到fpga取反回传的数据;
而上位机直接写BULK OUT->上位机再读BULK IN却无法读到fpga取反回传的数据,限时超时。
dingy 发表于 2017-4-15 20:41 | 显示全部楼层
貌似碰到过这个问题,想想啊我
 楼主| chenjunt 发表于 2017-4-15 20:52 | 显示全部楼层
嗯,68013A与FPGA对接,68013A配置为异步Slave FIFO模式。
renyaq 发表于 2017-4-15 20:54 | 显示全部楼层
时间太久了,楼主还有其他信息吗
 楼主| chenjunt 发表于 2017-4-15 20:55 | 显示全部楼层
windows驱动基于EZusb老驱动开发,USB驱动读写过程增加了超时退出机制。
Bus hound抓取结果
  Phase  - Phase Type
            CTL   USB control transfer
            IN    Data in transfer
            OUT   Data out transfer
            URB   USB request block
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
Device  Phase  Data                      Description       Cmd.Phase.Ofs(rep)
  21.0  CTL    40 b3 00 00  00 00 0a 00  VENDOR                   1.1.0      1.上位机先读BULK IN,超时
  21.0  OUT    00 00 00 00  78 f8 12 00  ....x...                 1.2.0
               42 18                     B.                       1.2.8
  21.0  URB    50 00 08 00  00 00 00 00  CONTROL TRANSFER         1.3.0
               98 53 44 82  20 00 00 00                           1.3.8
               b0 53 44 82  0a 00 00 00                           1.3.16
               0a 00 00 00  00 00 00 00                           1.3.24
  21.6  URB    48 00 09 00  00 00 01 c0  BULK/INT XFER            2.1.0
               98 53 44 82  20 00 00 00                           2.1.8
               f4 27 30 82  03 00 00 00                           2.1.16
               00 00 00 00  00 00 00 00                           2.1.24
  21.0  CTL    40 b3 00 00  00 00 0a 00  VENDOR                   3.1.0      2.上位机写0X5555(BULK OUT)
  21.0  OUT    02 00 00 00  50 fe 12 00  ....P...                 3.2.0
               bc 29                     .)                       3.2.8
  21.0  URB    50 00 08 00  00 00 00 00  CONTROL TRANSFER         3.3.0
               98 53 44 82  20 00 00 00                           3.3.8
               b0 53 44 82  0a 00 00 00                           3.3.16
               0a 00 00 00  00 00 00 00                           3.3.24
  21.2  OUT    55 55                     UU                       4.1.0
  21.2  URB    48 00 09 00  00 00 00 00  BULK/INT XFER            4.2.0
               98 53 44 82  20 00 00 00                           4.2.8
               d4 27 30 82  02 00 00 00                           4.2.16
               02 00 00 00  00 00 00 00                           4.2.24
  21.0  CTL    40 b3 00 00  00 00 0a 00  VENDOR                   5.1.0      3.再读(BULK IN),FPGA取反0xaaaa,读取ok
  21.0  OUT    00 00 00 00  78 f8 12 00  ....x...                 5.2.0
               42 18                     B.                       5.2.8
  21.0  URB    50 00 08 00  00 00 00 00  CONTROL TRANSFER         5.3.0
               98 53 44 82  20 00 00 00                           5.3.8
               b0 53 44 82  0a 00 00 00                           5.3.16
               0a 00 00 00  00 00 00 00                           5.3.24
  21.6  IN     aa aa                     ..                       6.1.0
  21.6  URB    48 00 09 00  00 00 00 00  BULK/INT XFER            6.2.0
               98 53 44 82  20 00 00 00                           6.2.8
               f4 27 30 82  03 00 00 00                           6.2.16
               02 00 00 00  00 00 00 00                           6.2.24
  21.0  CTL    40 b3 00 00  00 00 0a 00  VENDOR                   7.1.0      1.上位机直接写0X1111(BULK OUT)
  21.0  OUT    02 00 00 00  50 fe 12 00  ....P...                 7.2.0
               bc 29                     .)                       7.2.8
  21.0  URB    50 00 08 00  00 00 00 00  CONTROL TRANSFER         7.3.0
               98 53 44 82  20 00 00 00                           7.3.8
               b0 53 44 82  0a 00 00 00                           7.3.16
               0a 00 00 00  00 00 00 00                           7.3.24
  21.2  OUT    11 11                     ..                       8.1.0
  21.2  URB    48 00 09 00  00 00 00 00  BULK/INT XFER            8.2.0
               98 53 44 82  20 00 00 00                           8.2.8
               d4 27 30 82  02 00 00 00                           8.2.16
               02 00 00 00  00 00 00 00                           8.2.24
  21.0  CTL    40 b3 00 00  00 00 0a 00  VENDOR                   9.1.0      2.再读(BULK IN),超时退出 error
  21.0  OUT    00 00 00 00  78 f8 12 00  ....x...                 9.2.0
               42 18                     B.                       9.2.8
  21.0  URB    50 00 08 00  00 00 00 00  CONTROL TRANSFER         9.3.0
               98 53 44 82  20 00 00 00                           9.3.8
               b0 53 44 82  0a 00 00 00                           9.3.16
               0a 00 00 00  00 00 00 00                           9.3.24
  21.6  URB    48 00 09 00  00 00 01 c0  BULK/INT XFER           10.1.0
               98 53 44 82  20 00 00 00                          10.1.8
               f4 27 30 82  03 00 00 00                          10.1.16
               00 00 00 00  00 00 00 00                          10.1.24
xxrs 发表于 2017-4-15 20:57 | 显示全部楼层
驱动ezusb.sys已经很老了,难免会有一些问题的,建议楼主使用Cyusb.sys试试。
 楼主| chenjunt 发表于 2017-4-15 20:59 | 显示全部楼层
其实还是不大明白,我再琢磨琢磨吧,多谢了哈,结贴了先
