为什么我不能用ICD2和IDE8.5进行调试?
3143|0
 楼主| fushun6 发表于 2010-5-5 12:42 | 显示全部楼层 |阅读模式
Connecting to MPLAB ICD 2
...Connected
Setting Vdd source to target
Target Device PIC16F877A found, revision = Rev 0x8
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 ready for next operation
Resetting Target
Resetting Target
Programming Target...
...Validating configuration fields
ICDWarn0013: Low Voltage Programming cannot be enabled when ICD 2 is used as a debugger.  Disable Low Voltage Programming?
ICDWarn0014: Watchdog Timer cannot be enabled when ICD 2 is enabled as a debugger.  Disable Watchdog Timer?
...Erasing Part
...Programming Program Memory (0x0 - 0x1807)
...Loading DebugExecutive
...Programming DebugExecutive
...Programming Debug Vector
Verifying...
...Program Memory
...Debug Executive
...Debug Vector
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
Connecting to debug executive
ICD0083: Debug:  Unable to enter debug mode.  Please double click this message for more information.
