[牛人杂谈] 身边的新塘+我的M058开发板
1337|10
 楼主| gaoyang9992006 发表于 2017-4-20 21:18 | 显示全部楼层 |阅读模式
 楼主| gaoyang9992006 发表于 2017-4-20 21:19 | 显示全部楼层
这个板子小巧便携,很容易收放,自带强大的Nu-Link-Me编程器,还可以为自己做的板子烧录程序。
 楼主| gaoyang9992006 发表于 2017-4-20 21:24 | 显示全部楼层
这里奉上相关资源
其实可以很容易的借鉴里面的原理图,搭建自己项目的最小电路部分。
这里奉上相关资源
NuTiny-SDK-M058SSAN.zip (411.34 KB, 下载次数: )
gejigeji521 发表于 2017-4-20 22:42 | 显示全部楼层
板子不错啊, 上面的主控全是新唐自己的。
 楼主| gaoyang9992006 发表于 2017-4-21 10:10 | 显示全部楼层
* @file     main.c
* @version  V3.00
* $Revision: 5 $
* $Date: 15/02/06 10:22a $
* @brief    Show the usage of GPIO interrupt function.
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M058S.h"
#define PLL_CLOCK           50000000
* @brief       Port0/Port1 IRQ
* @param       None
* @return      None
* @Details     The Port0/Port1 default IRQ, declared in startup_M058S.s.
void GPIOP0P1_IRQHandler(void)
    /* To check if P1.3 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P1, BIT3))
        GPIO_CLR_INT_FLAG(P1, BIT3);
        printf("P1.3 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT0, PORT1 interrupts */
        P0->ISRC = P0->ISRC;
        P1->ISRC = P1->ISRC;
        printf("Un-expected interrupts.\n");
* @brief       Port2/Port3/Port4 IRQ
* @param       None
* @return      None
* @details     The Port2/Port3/Port4 default IRQ, declared in startup_M058S.s.
void GPIOP2P3P4_IRQHandler(void)
    /* To check if P4.5 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P4, BIT5))
        GPIO_CLR_INT_FLAG(P4, BIT5);
        printf("P4.5 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT2, PORT3 and PORT4 interrupts */
        P2->ISRC = P2->ISRC;
        P3->ISRC = P3->ISRC;
        P4->ISRC = P4->ISRC;
* @brief       Port5 IRQ
* @param       None
* @return      None
* @details     The Port5 default IRQ, declared in startup_M058S.s.
void GPIOP5_IRQHandler(void)
    /* To check if P5.2 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P5, BIT2))
        GPIO_CLR_INT_FLAG(P5, BIT2);
        printf("P5.2 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT5 interrupts */
        P5->ISRC = P5->ISRC;
* @brief       Port6/Port7 IRQ
* @param       None
* @return      None
* @details     The Port6/Port7 default IRQ, declared in startup_M058S.s.
void GPIOP6P7_IRQHandler(void)
    /* To check if P6.1 interrupt occurred */
    if(GPIO_GET_INT_FLAG(P6, BIT1))
        GPIO_CLR_INT_FLAG(P6, BIT1);
        printf("P6.1 INT occurred.\n");
    else
        /* Un-expected interrupt. Just clear all PORT6 and PORT7 interrupts */
        P6->ISRC = P6->ISRC;
        P7->ISRC = P7->ISRC;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_OSC22M_EN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_OSC22M_STB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLK_S_HIRC, CLK_CLKDIV_HCLK(1));
    /* Enable external XTAL 12MHz clock */
    CLK_EnableXtalRC(CLK_PWRCON_XTL12M_EN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_CLKSTATUS_XTL12M_STB_Msk);
    /* Set core clock as PLL_CLOCK from PLL */
    CLK_SetCoreClock(PLL_CLOCK);
    /* Enable UART module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select UART module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART_S_PLL, CLK_CLKDIV_UART(1));
    /* Init I/O Multi-function        */
    /* Set P3 multi-function pins for UART0 RXD and TXD */
    SYS->P3_MFP &= ~(SYS_MFP_P30_Msk | SYS_MFP_P31_Msk);
    SYS->P3_MFP |= (SYS_MFP_P30_RXD | SYS_MFP_P31_TXD);
void UART0_Init(void)
    /* Init UART        */
    /* Reset UART0 */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
/* MAIN function        */
int main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    /* Init System, peripheral clock and multi-function I/O */
    SYS_Init();
    /* Lock protected registers */
    SYS_LockReg();
    /* Init UART0 for printf */
    UART0_Init();
    printf("\n\nCPU @ %d Hz\n", SystemCoreClock);
    printf("+------------------------------------------------------+\n");
    printf("|    GPIO P1.3/P4.5/P5.2/P6.1 Interrupt Sample Code    |\n");
    printf("+------------------------------------------------------+\n\n");
    /* GPIO Interrupt Function Test        */
    printf("P1.3/P4.5/P5.2/P6.1 are used to test interrupt ......\n");
    /* Configure P1.3 as Input mode and enable interrupt by rising edge trigger */
    GPIO_SetMode(P1, BIT3, GPIO_PMD_INPUT);
    GPIO_EnableInt(P1, 3, GPIO_INT_RISING);
    NVIC_EnableIRQ(GPIO_P0P1_IRQn);
    /*  Configure P4.5 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    GPIO_SetMode(P4, BIT5, GPIO_PMD_QUASI);
    GPIO_EnableInt(P4, 5, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPIO_P2P3P4_IRQn);
    /*  Configure P5.2 as Input mode and enable interrupt by rising and falling edge trigger */
    GPIO_SetMode(P5, BIT2, GPIO_PMD_INPUT);
    GPIO_EnableInt(P5, 2, GPIO_INT_BOTH_EDGE);
    NVIC_EnableIRQ(GPIO_P5_IRQn);
    /*  Configure P6.1 as Quasi-bidirection mode and enable interrupt by falling edge trigger */
    GPIO_SetMode(P6, BIT1, GPIO_PMD_QUASI);
    GPIO_EnableInt(P6, 1, GPIO_INT_FALLING);
    NVIC_EnableIRQ(GPIO_P6P7_IRQn);
    /* Waiting for interrupts */
    while(1);
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
yiyigirl2014 发表于 2017-4-21 15:46 | 显示全部楼层
NuTiny系列的板子也是我的最爱,这个板子太适合DIY了。
wahahaheihei 发表于 2017-4-21 19:04 | 显示全部楼层
收下楼主发的新唐资料。
稳稳の幸福 发表于 2017-4-21 20:18 | 显示全部楼层
后面的是焊丝和三极管吧。
598330983 发表于 2017-4-22 19:20 | 显示全部楼层
三部搞定一个端口 中断配置,设置模式,使能中断,加入中断向量。
xixi2017 发表于 2017-4-22 20:22 | 显示全部楼层
希望楼主多多分享点资料啊
2053
