使用stm32f101的时钟问题
5181|3
 楼主| kexd2004 发表于 2010-5-6 11:49 | 显示全部楼层 |阅读模式
我用的芯片是stm32f101vbt6,只能工作在36MHz,我用的初始化函数都是开发板上移过来的(用的是103系列,即工作在72MHz),我的板子是能“正常”工作,加了引号是我的定时器2定时时间不对,想弱弱的问几个问题:
1.我初始化时钟为72MHz,板子也能工作,为什么呢
2.我试着修改RCC_Configuration(),再看定时器效果,慢了一半。不知是否已经成功修改了时钟为36MHz呢
void RCC_Configuration(void)
    ErrorStatus HSEStartUpStatus;
    // Reset the RCC clock configuration to default reset state
    RCC_DeInit();
    // Configures the High Speed External oscillator
    RCC_HSEConfig(RCC_HSE_ON);
    // Waits for HSE start-up
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
    if(HSEStartUpStatus == SUCCESS)
        // Enable Prefetch Buffer
        FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
        // Sets the code latency value: FLASH Two Latency cycles
        FLASH_SetLatency(FLASH_Latency_2);
        // Configures the AHB clock(HCLK): HCLK = SYSCLK
        RCC_HCLKConfig(RCC_SYSCLK_Div1);
        // Configures the High Speed APB2 clcok(PCLK2): PCLK2 = HCLK
        RCC_PCLK2Config(RCC_HCLK_Div1);
        // Configures the Low Speed APB1 clock(PCLK1): PCLK1 = HCLK/2
        RCC_PCLK1Config(RCC_HCLK_Div2);
        // Configures the PLL clock source and multiplication factor
        // PLLCLK = HSE*PLLMul = 8*9 = 72MHz
        //RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);//原程序
      RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_9);//my modify:测试看到time2 减慢一半,但到底是不是工作在 36 MHz?
        // Enable PLL
        RCC_PLLCmd(ENABLE);
        // Checks whether the specified RCC flag is set or not
        // Wait till PLL is ready
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
        // Select PLL as system clock source
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
        // Get System Clock Source
        // Wait till PLL is used as system clock source
        while(RCC_GetSYSCLKSource() != 0x08);
  /* Enable Clock Security System(CSS) */
     RCC_ClockSecuritySystemCmd(ENABLE); //new add:css(时钟安全系统),外部晶振失效时可以切换到HSI(内部RC)
香水城 发表于 2010-5-6 12:12 | 显示全部楼层
1)超频也能工作,但不代表能稳定工作。
2)正确。还可以通过在MCO引脚输出CPU时钟信号验证。
 楼主| kexd2004 发表于 2010-5-6 14:36 | 显示全部楼层
yes,thx a lot
txcy 发表于 2010-5-6 21:21 | 显示全部楼层
超频一般稳定性就相应差些了
