[技术求助]
THS4275的关断模式是什么呀
465|9
zhanghqi|  楼主 | 2017-5-1 22:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
jiahy| | 2017-5-1 22:28 | 只看该作者
THS4275的Pin8是关断引脚
shimx| | 2017-5-1 22:33 | 只看该作者
低电平可以控制芯片关断。
zhanghqi|  楼主 | 2017-5-1 22:34 | 只看该作者
哦,这样啊
huangchui| | 2017-5-1 22:36 | 只看该作者
是的,2,3楼正解
shimx| | 2017-5-1 22:41 | 只看该作者
还是不能编译,我用wave仿真程序编译,Timer的高低位能否这样赋值?
shimx| | 2017-5-1 22:43 | 只看该作者
不计算有没有简洁的赋值语句
zhanghqi|  楼主 | 2017-5-1 22:45 | 只看该作者
结贴了,多谢大家讨论这么多哈,呵呵
airwill| | 2017-5-6 08:06 | 只看该作者
这个应该不能叫 关断, 因为手册称为 Power Down
Power-Down Reference Pin Operation
In addition to the power-down pin, the THS4275 also features a reference pin (REF) which allows the user to control the enable or disable power-down voltage levels applied to the PD pin. Operation of the reference pin as it relates to the power-down pin is described below.
In most split-supply applications, the reference pin is connected to ground. In some cases, the user may want to connect it to the negative or positive supply rail. In either case, the user needs to be aware of the voltage level thresholds that apply to the power-down pin. Table 2 and Table 3 show examples and illustrate the relationship between the reference voltage and the power-down thresholds.
comeon201208| | 2017-5-7 16:03 | 只看该作者
这个没怎用过,不过一般都是通过特定管脚进行控制的。
