[技术求助]
TS脚怎么处理
587|5
wuhany|  楼主 | 2017-5-14 22:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
lizye| | 2017-5-14 22:35 | 只看该作者
看情况   一般是将空管脚设置为高电平输出   这样闲置管脚不会因为外界环境等原因对MCU本身造成干扰
huangchui| | 2017-5-14 22:37 | 只看该作者
关于这个 TS, 是个温度检测端口.  手册有这么一段话:
The bq27541 measures battery temperature via the TS input, in order to supply battery temperature status information to the fuel gauging algorithm and charger-control sections of the gauge. Alternatively, the gauge can also measure internal temperature via its on-chip temperature sensor, but only if the [TEMPS] bit of Pack Configuration register is cleared.
Regardless of which sensor is used for measurement, a system processor can request the current battery temperature by calling the Temperature( ) function (see Section Standard Data Commands, for specific information).
The thermistor circuit requires the use of an external 10Kohm thermistor with negative temperature coefficients, such as Semetic 103AT-type thermistor that connects between the Vcc and TS pins. Additional circuit information for connecting this thermistor to the bq27541 is shown in Section 4, Reference Schematic.
zhanghqi| | 2017-5-14 22:39 | 只看该作者
悬空的不管就行啦。。
zhenykun| | 2017-5-14 22:42 | 只看该作者
wuhany|  楼主 | 2017-5-14 22:45 | 只看该作者
嗯,我再好好缕一缕吧,有了好消息及时通知大家,结贴喽
